I have a 94 LT1 6speed coupe. I drove a customer's 95 LT1 today and his felt a bit like a dog. I was curious if the previous owner of mine could have changed the gears. I can run in 6th at 40 MPH with little to no bogging. My build decal says I have RPO GM3 3.45 rear gears from the factory.
I would like for you guys to chime in and test this for me. Let me know what RPMs you turn in 4th gear at 55 MPH. I am at 2500 to 2550.
I have a 91 with the same setup (6spd w/3:45 rear). I don't get out of work 'till 8pm, then straight to my little guys baseball game, so I'll let you know, but it won't be until about 10:30 est.
If you do the math 3.45 gears at 55MPH should be 2472 RPM.
Could be. I know that he still had the stock CAGS hooked up and it made me shift to 4th early. In mine, I can pull 4th from 15 mph, his just did not feel like it would.
