Im building a 383 for my 85 vette
and am going with a double roller timing chain and was wandering if i should advance or retard my timing at all?
retard=tq
advance=hp
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
retard=tq
advance=hp
at least thats what the package says
That's simplistic. Advancing or retarding the chain will move the torque curve up or down the HP curve.
I was figuring on leaving it alone
but wanted a 2nd opinion on it before i sealed it all up thanks
If you look at your cam card I'll bet the cam is ground +4. It is a very common for the grinder to do this since most cam buyers select a cam that is too large. Install it straight up. If you are looking for the absolute max for an almost pure race engine degree it in with the correct keys.
NOT a race engine thats for sure
just gonna be my DD
and its the stock cam and i have no idea what the cam actually is or what the numbers that accompany any cam represent
retard=tq
advance=hp
I agree with the above ...just put it in straight up. This is a "fine tuning" trick to compensate for the Cam or having class rules that require a stocker. BTW it's Adv=TQ Retard=HP. Some Timing Chain Covers have problems clearing Double roller chains.
well my cam has 1 degree advance ground in and was suppose to be 108 intake centerline installed. Lined up the dots on the timing chain and degreed it... it was retarded 2 degrees so i moved it back 2 with my timing set that has 9 keyholes.
got it back where it should be. Installing straight up using dot to dot doesnt always give accurate results, so its best to degree it. Kind of a PITA but its best to know where your cam timing is at
Some may not buy into this, but the engine that won the Engine Masters Challenge made best all-around torque and HP with the cam advanced eight degrees.
Cam was ground on 106 and installed at 98.
Following the timing card is probably the best way to start, but it's only a starting point. Depending on the results you get with it set that way - ground, on say 112 and installed at 108, (which'll account for the 4 degrees many times ground in by the can maker) -, you may want to tweak that setting down the road.
My XFI was ground on 113 and installed at 109 - per the card - but I'd planned to move it to 106. As long as your piston to valve isn't critical, you can play around with the setting until you hit the one you like best.
Way back... some would advance or retard the Cam a few degrees... turn the motor over while checking which setting made the most compression. They would set it there. I don't know for sure if this method is still used, or how effective it is.
like i said i have no idea what the cam numbers mean
and im just leaving it at the stock setting
i plan on a heads/cam swap eventually so then ill play with it some
just want it running right now
