TRW Piston identification..
However, are you interested in trying a different approach to
identifying the compression ratio? If so, what are the casting numbers
on the heads and on the block?
As for the shape of the piston tops, you may be able to do a visual
through the plug hole & exhaust port. (A borescope like the ProVision
PV-636 would make determination a snap.)
There may be people who can determine the compression ratio of
an engine assembled from a collection of unknown part dimensions,
but I am not one of them.
If you wanted to amuse yourself for a while, you could play what-if
with one of the on-line calculators as below, but my vote is that
further physical investigation lies ahead.
Compression Calculator
Assume
4.030" gasket bore
0.040" compressed gasket thickness
76 cc chamber volume
0.00" deck
_9.6:1 (00 cc dome)
10.8:1 (+10 cc dome)
