Pre Cats
Old Apr 19, 2008 | 03:53 PM
RG86VET's Avatar
RG86VET
Default Pre Cats
Can I Remove The Pre-cats And Keep The Converter And Install Muffler Eliminators, Will This Be A Noticeable Diffrence In Performance And How Loud Is This Going To Be, I Have A 86
Old Apr 19, 2008 | 04:33 PM
frenchyoliver's Avatar
frenchyoliver
take away the pre-cats but do not guter them or it will drone.
have a high flow cat 150$ ok.
elim will be loud and cause resonance.
Old Apr 19, 2008 | 04:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Have a 2 1/2" pre-catless front Y along with a hi-flow main cat to pass emissions tests and receive max benefit.
You will get about a 15chp gain from the above cats change; not sure what gain the elims will bring but they will be LOUD...
Old Apr 19, 2008 | 04:52 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I eliminated pre cats and went to a high flow main cat. I have dual outlet OEM style Magnaflows. Drone only between 1200 and 1600 rpm's.
Old Apr 19, 2008 | 05:32 PM
LKoncar's Avatar
LKoncar
I've got a front cat-less y , high flow cat and stinger mufflers from MAM. Nice sound at wot. Not that bad when cruising
To Pre Cats
