Wide Band O2
Old Apr 19, 2008 | 09:03 PM
aboatguy's Avatar
aboatguy
Default Wide Band O2
For those that own them;
what WBO2 system are you using? Does it data log?
Mike
Old Apr 19, 2008 | 09:56 PM
AKS Racing's Avatar
AKS Racing
Part of the aftermarket units that I run. FAST, Accel DFI, and BS3. These systems datalog.
I am sure you are looking for info on stand alone systems, so someone else may chime in.
Aaron
Old Apr 19, 2008 | 10:46 PM
BAM92's Avatar
BAM92
Aaron
Comes with my FAST system. Buddy is using the Innovate standalone and works great.
Old Apr 20, 2008 | 04:55 AM
Happydad's Avatar
Happydad
Innovate Stand alone...I just plug it in to my laptop...Can be finicky..I'm T&T next Sat on a dyno and will compare readings..
Old Apr 20, 2008 | 06:46 AM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Innovate Motorsports LM1 w/ RPM cable. The RPM cable allows RPM data logging plus 5 other low voltage (0-5) inputs. I data log A/F, RPM, MAF sensor voltage, & TPS voltage. I make my fueling adjustments (MAF tables) using that info alone. The LM1 software has some nice capabilities and you can view the information in a graph format. The files can also be opened up in Excel, which really helps me pinpoint AFR vs MAF voltage mapping for MAF table adjustments.
Old Apr 21, 2008 | 09:11 AM
FastVette94's Avatar
FastVette94
I use the unit from TechEdge found here: http://wbo2.com/
They have a unit with dual widebands for the L and R side. The unit also outputs a narrow band range which can be fed back into the stock ECU so the exisiting bungs can be used.
It works great for me; I've tuned my 383 LT1 on motor and bottle, and also ran the unit on my brothers 69 Z28 Methanol Injected motor (950+ HP). I dialed in his high-speed lean out with the wideband a couple weeks ago.
It logs AFR, RPM, Exhaust Temps, etc.
Old Apr 21, 2008 | 09:59 PM
DBall's Avatar
DBall
Fast Vette,
I am also looking for a wide band O2 sensor that will send data to a pc for correlation when data logging with Tuner Pro or Scanner pro or Datamaster. Do you use this with data logging too ? Thx,
Mstrs 2
'90 383
Super Ram
Old Apr 22, 2008 | 07:21 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Originally Posted by DBall
Fast Vette,
Mstrs 2
'90 383
Super Ram
Good question! I have TunerPro and ScannerPro and I also have an LM1 wideband. The injection system I have on my engine uses a narrow band sensor and I can data log all the injection system parameters with ScannerPro. I also have a separate wide band O2 sensor on the engine (not connected to the injection system) and I can log the wide band data with the LM1. I would like to compare the two O2 sensor readings but the problem is how to synchronize the two data logs. Ideally I would like to be able to log the wide band data with ScannerPro, but I don't know if that is possible.
Charles
Old Apr 22, 2008 | 09:38 AM
GRX's Avatar
GRX
Innovate Motorsports LM1; LM3; XD1. Yes datalogs.
Old Apr 22, 2008 | 10:20 AM
rickneworleansla's Avatar
rickneworleansla
Fast Vette,
Mstrs 2
'90 383
Super Ram
I need something to use with Datamaster TTS and TunerCat Software (RT Tuner).
Old Apr 25, 2008 | 08:43 PM
DBall's Avatar
DBall
Default Wide band O2
Has anyone used the Zeitronix Zt-2 ? It looks like a good buy to me. Now need to figure out how to hook up the wiring. TIA, Dave
To Wide Band O2
