Correct factory wire looms position?
Old Apr 20, 2008 | 12:14 AM
Calderone's Avatar
Calderone
Default Correct factory wire looms position?
I already ordered the factory complete wire retainers kit from midamerica,so its time to put this metal wire looms back in to put the plastics from midamerica
i found this driver's side picture but im missing passenger side
and other metallic looms are not pictured ..where do they go ?
My looms ..currently uninstalled (please avoid the broken temp sensors on top right)
Old Apr 20, 2008 | 12:24 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There are two metal loom holders on the side of the head and two wire channels under the insulated EGR tube; the lower holds three wires, the upper holds one wire. In all cases these four wires pass through (I believe) heat resistant spiral wrap to help isolate them from the hot metal.
Old Apr 20, 2008 | 12:26 AM
Calderone's Avatar
Calderone
is this pictured above ?
thanks!
Old Apr 20, 2008 | 12:42 AM
65Z01's Avatar
65Z01
There's a pic in my FSM but my digi camera is down so can't snap off a shot for ya, sorry.
Old Apr 20, 2008 | 12:48 AM
Calderone's Avatar
Calderone
Don't worry,i hope someone can tell us
thanks anyway
Old Apr 20, 2008 | 01:36 AM
65Z01's Avatar
65Z01
Since my digi camers is now working (ghosts I tell ya) you have mail with a pic of the plug wiring from my FSM.
Though that diagram doesn't seem to show the two metal brackets that hold the wires against the RH head away from the EGR tube nor the black spiral wrap around said wires.
Anyway hope it helps.
Old Apr 20, 2008 | 01:39 AM
Calderone's Avatar
Calderone
thanks 65
i will try to install them as close as factory as i can
thanks !!!
To Correct factory wire looms position?
