Condenser Coil Screws
Old Apr 20, 2008 | 12:29 AM
fnsblum's Avatar
fnsblum
Default Condenser Coil Screws
I was under the car this morning removing the air dam for painting. As is always the case I was looking around with my drop light. At the top of the condenser I saw two screws screwed right into the coil fins. The two screws were the two outboard that hold the filter in place. If they had been just an 1/8" longer they would have punctured the coil. I shortened them up approximately 1/4". They look a lot better. You might want to check yours. Later! Frank
