84 cross fire 4spd
Old Apr 21, 2008 | 10:23 AM
pappyfreebird's Avatar
pappyfreebird
Default 84 cross fire 4spd
what should it idle at? both cold and warmed up? and what to check since idles at 14 cold start...then at 180 degrees she drops to 800 rpm...also did jus have cat back replaced and is quieter ,,,could i need to unhook battery...tps was repalced before i bought it...still idles 800 hot 1400 -1500 cold till hits 180 temp
Old Apr 21, 2008 | 12:18 PM
qws's Avatar
qws
Mine idles when cold at about 1400-1600 rpm
Once hot it drops to about 600 rpm
Old Apr 21, 2008 | 12:45 PM
JLeatherman's Avatar
JLeatherman
On my 84 the "fully warm" temp was 187*. As soon as the car hit that temp my overdrive started working and the idle dropped down to where it was supposed to be. If yours does all of the above it's fine. Mine used to idle up towards 195-205 with the stock thermostat in traffic, which is plenty warm but not hurting anything. Seems to me I had the idle in mine set around 750rpms, but I messed with it so often it was always changing.
Old Apr 21, 2008 | 01:19 PM
pappyfreebird
thank you guys...seems im ok then (well my car is ),,,cause 14-1500 cold at 180 drops to 7-9 mostly 800,,,and thats when od werks too...high strung lil buggars aint they...she sure has won my heart awready... thanks again...still seems they should idle 5-600 but seems its done by sensors n ecm,,,anyway to lower it the ol fashioned way (like ear n screwdriver)
Old Apr 21, 2008 | 01:31 PM
CFI-EFI's Avatar
CFI-EFI
Spell check is your friend. The idle speed isn't as complicated as you try to make it out to be. The idle speed is programmed into the chip. It is not to be user adjusted. If you have no vacuum leaks and the TBs are synchronized, your engine should idle at 600 rpm in drive, as smooth as a fine Swiss watch. It doesn't take anything but a little good old fashioned tinkering. Don't let the electronics snow you.
RACE ON!!!
Old Apr 22, 2008 | 08:26 PM
pappyfreebird
no obvious vacuem leaks,,,all seems fine ceptin lil too high after warm 8-900,,,no stumbles runs good...maybe hafta try n dig in under dash at vent hoses n see,,,but they seem ta werk ok too
Old Apr 23, 2008 | 07:50 AM
pappyfreebird
ok ive paid more attention to heat vent n defrost,, and she is non too fast at changing from vent to defrost for example,,,so any quick happind to me tips on where to stuff my paw to git er done .. thanks paps
Old Apr 24, 2008 | 09:47 AM
pappyfreebird
well closer looks at vacuem lines n i d like 5 minutes alone with the idjut that designed that mess...anyway did find a few that had been babba"d,,,n since hes my cousin i did same (used rubber line to splice the hard palstic junque ones) still idles at 8-900 but defrost n vent moves real noicely
Old Apr 24, 2008 | 10:27 AM
CFI-EFI's Avatar
CFI-EFI
Check and/or reset your minimum air adjustment.
RACE ON!!!
Old Apr 24, 2008 | 01:35 PM
JLeatherman
I'd give her a good old crossfire tuneup. If it idles smooth and runs strong your TB's are likely to be in good shape. The tune-up procedure I read from a mag article a while back was
Remove, Clean, and re-gasket the IAC's
Check/Adjust minimum timing
Balance the TB's
Normal SBC tuneup of plugs/wires/etc
Now, you can check your TB sync with a manometer and if they're not out of sync you don't need to adjust them. Checking them is easy, just hook up the gauge to the right ports. Adjusting them is a bit trickier, and you gotta grind off some factory welds. If you want more information about the crossfire system check out
http://crossfire.home-ip.net
I'll see if I can still find that article on the crossfire tuneup. Oh yeah, once you clean the IACs you gotta reset your battery so the car will be forced to "relearn" the settings. You might have an IAC that's sticking partly open causing your higher idle.
Old Apr 24, 2008 | 01:37 PM
JLeatherman
Found the article I was looking for. This one helped me a lot on my first tuneup on my '84.
http://www.corvettefever.com/techart...ing/index.html
I even re-read it just now and forgot to add something. It might be an out of adjustment TPS causing your idle issues. Altering the TPS can make the car think you're pressing the gas. While the idle may be "pre-programmed" you can trick the car into idling higher by altering the TPS. Check it out.
Old Apr 24, 2008 | 07:58 PM
pappyfreebird
thanks guys ...the previous owner did put in a tps trying to lower idle...jl i dont think all the writtng was there it ended at theyll do it fer 275...im not pc savvy (kin ya tell)so if im missin something id preciate the push
hey cfi ,,, i preciate yer help also,,but air adjustment to me means on the front of carb,,,so ill have to learn what you said or where its at n what you do thanks fellas paps
i rekon i start next with the iac,,, should be one in each tbi right?? maybe plugs n wires just cause... but dont see where theyed cause high idle
Old Apr 24, 2008 | 08:27 PM
CFI-EFI's Avatar
CFI-EFI
Changing the TPS isn't going to lower the idle. It DOES need to be properly adjusted, however.
Once again in English. None of that makes any sense to me.
I didn't know what it was until I got my '84 (22 years ago) and wanted to learn about it. The FSM is an excellent place to start.
If the IACs are plugged up, they would pass less air and the engine would idle too low, not too high. You are right about the plugs and wires.
Real words, proper English, capital letters and punctuation, plus better spelling, would all help to make your posts easier to read and understand, in order to provide help.
RACE ON!!!
Old Apr 24, 2008 | 09:08 PM
pappyfreebird
the vet idles at 15-1600 cold ,,,at 180 degrees idle drops off to 8-1000 rpm,,,to high,,,what can i do to fix it???
Old Apr 24, 2008 | 10:08 PM
JLeatherman
If the TPS were improperly adjusted the car *could* think that the gas pedal is slightly depressed and add more fuel. The IAC's would then have to open up to keep the car properly lean and the idle would be high.
IACs being plugged would idle too low, but IACs stuck open, or one stuck open, would cause an idle too high.
Not arguing with ya CFI, just offering some clarification to my earlier suggestions. Two simple, good places to start.
Clean the IACs (read the article, it says not to get cleaner into the stepper motors) and tighten them back down. Then adjust the TPS using a multimeter. Once that is done reset the battery by disconnecting the battery for a couple minutes, and then start the car and drive it around a bit, making sure to hit atleast 45mph. Don't be surprised if it starts and runs poorly at first, it needs to relearn everything.
Old Apr 24, 2008 | 10:11 PM
JLeatherman
As for the article, it does seem to have gotten abbreviated. Perhaps eMail the CF webmaster and find out what happened to it. It used to be all there, and it was VERY informative.
Old Apr 25, 2008 | 10:01 AM
pappyfreebird
i thank you jl,,,now this morning after warm up she dropped off to 7-800 n that 7 range id say would be fine...ill have a look at those iac s n the tps ...im no good at all with this new stuff...never was good but never paid anybody yet either...thats where you cats are great...thanks pappy.. i keep ya posted on what i break
To 84 cross fire 4spd
Old Apr 27, 2008 | 12:36 PM
pappyfreebird
ok i tried the muti meter thing on the tps n didnt git jack ... i ran jumper wires and touched a to b with multi meter,,, switch on and only way got any reading was touching the top one and then either of the lower ones...so probably did it wrong ,,,used a sears multi meter set on vdc fer volts ...but tps was set at its lowest point so did move it around a bit ,,then ended up puttin back as was,,,havent had time to check the iacs yet..anyone want to explain (real slow ) the way to set tps ,,,thanks paps
Old Apr 27, 2008 | 12:45 PM
CFI-EFI's Avatar
CFI-EFI
www.helminc.com
RACE ON!!!
Old Apr 27, 2008 | 07:10 PM
pappyfreebird
haynes!!! it simply says ifn readings not in the 535 then replace the tps...thats why i feel i ain doin it right cause its a new tps...ill get it eventually...thanks JL n cf
