An info post regarding my ZF6 conversion
I have a L98ish stroker crank that sticks out from the block 18mm
the bellhousing (p/n magnesium 10126448) surface to surface is 153.8mm. This measurement includes the two 0.032" "isolation" shims on either end of the bell housing.
The transmission (blue tager) juts into the bellhousing 13mm not including the front bolts. I measured my diameter to be 33.4mm (1.31")
thus the clearance from crank surface to transmission is 153mm - 18mm - 13mm = 122.8mm (4.83").
I talked to the ram clutch dude in S. Carolina. Their twins range from 3.1" to 3.16" crank to clutch fingers and require 0.450" to accuate. Thus the Hyd TB needs to be 1.675" - 1.735".
... doable except that the ram twins are 168 tooth vice the vette 153 tooth and that you need some sort of bearing race between the clutch fingers and the bearing.
Thoughts, additions, haters?
I have a Howe with a standard Ram PP, and spacers between my BH/Block.
Buy the Twin package that you want, then bolt the thin FW on and the clutch package,,, then bolt the Bell housing on,,, measure from the BH mount face to the clutch fingers....
Now take the HOWE brand TOB and slide it onto the tranny and measure from the TOB collapsed face to the tranny mount face....
Take the difference and make sure that you have the necessary TOB disengagement travel,,, plus @ .250" for clearance......
What ever your stack up totals, is what you need and what you lack can be added by using a spacer between the BH and the Block,,,,
Here is a link that describes this as well, but he is using a McLeod #1345 TOB. Personally, I would use the McLeod TOB if you can swing the cost.
Also, because of the TWIN package, you will need to consider your Master cylinder bore as well.
http://forums.corvetteforum.com/show....php?t=1740664
http://members.cisdi.com/~anesthes/zf6/
http://members.cisdi.com/~anesthes/projects/stick-swap/
I don't know if your car is auto or 4+3, but either way those to links have
it covered.
(and rather than posting BS, or posting what a mechanic in some shop said he did - everything in those links have been done and covered by me, and in most cases been apart and together numerous times and ways before I finalize the perfect solution).
-- Joe
it covered.
-- Joe
cool thanks for the info.
sigh!!!!!
-- Joe
