91 Corvette
Old Apr 22, 2008 | 08:38 AM
jbeeman2001's Avatar
jbeeman2001
3rd Gear
Default 91 Corvette
The solenoids for the two latches that hold down my convertible top keep firing back and forth, independently. It makes a double popping sound. I thought maybe water had gotten in the latches, but it happens overnight in my garage as well and I have to disconnect the battery to get it to stop. Any ideas of what maybe wrong, Is it the release button, or a computer problem?
Old Apr 22, 2008 | 08:44 AM
rich653's Avatar
rich653
I had the same problem with mine and found a loose wire on my hatch release button in the drivers door panel but there are several things that can cause it, if you had the door panels off recently that could be a sign also check the hatch release in the console gb to make sure somethings not hitting the button, just some ideas.
Old Apr 22, 2008 | 09:18 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
Loose wire is my vote.
Good luck!!
Old Apr 22, 2008 | 03:21 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I replaced my hatch release switches in the doors. You can get them at Ecklers for about $15 each. http://www.ecklers.com/product.asp?p...dept%5Fid=1663
To 91 Corvette
