Total time to replace injectors on L98??
Old Apr 23, 2008 | 10:13 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Why does it leak ? Bad O-Ring ? not enough torque ?
The O-ring/gasket that goes on the end of 9th injector feed line was cut so I replaced it with a very thin O-ring but that leaked so I need a new gasket.
Sorry to ask but .....what's a leaking injector ?
what's the symptoms?
The injectors can build up dirt over time so that they eventually can not completely close and fuel leaks into the engine. This usually works out ok for a cold motor but causes long crank times for a warm engine, which is a symptom of leaking injectors.
Old Apr 23, 2008 | 10:29 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Leaking injectors also can wash down cylinder walls and foul your motor oil.
