Total time to replace injectors on L98??
Old Apr 22, 2008 | 05:33 PM
Brett Richmond's Avatar
Brett Richmond
Default Total time to replace injectors on L98??
I have a 89 that has leaking injectors, how much time should it take to tear everything down and put back together with good skills??
Old Apr 22, 2008 | 05:42 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
2.5 TO 3 HRS
Old Apr 22, 2008 | 06:24 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Agree, i can tear down & replace in 3 hrs, having lunch and a beer all in the process, 87/L98
Old Apr 22, 2008 | 06:29 PM
Bobwhite85's Avatar
Bobwhite85
on my 85
Old Apr 22, 2008 | 06:33 PM
Aardwolf's Avatar
Aardwolf
Agreed, popping the plenum up and pulling the rail out to change them that way goes pretty well!
Old Apr 22, 2008 | 06:34 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by FICINJECTORS
2.5 TO 3 HRS
Unless you do it once a week, then it's 2 hours. Count all your screws.
Old Apr 22, 2008 | 07:01 PM
CFI-EFI's Avatar
CFI-EFI
With or without including checking out resultant strange noises? With or without including changing pistons? Worse case scenario, figure about 30 days and 400+ posts.
RACE ON!!!
joeld's Avatar
joeld
Hey jsup,glad to see your sense of humor is still intact.
Joel
Old Apr 22, 2008 | 08:16 PM
jsup's Avatar
jsup
Joel
Eh, crying isn't going to change anything.....I'd make fun of me too.
I did it for the education, and got one. I got what I wanted.
Old Apr 22, 2008 | 08:18 PM
jsup's Avatar
jsup
RACE ON!!!
Old Apr 22, 2008 | 08:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I just swapped the injectors on my '88 and the project is still in progress. I removed:
-the AIR pipe from pump to diverter
-AIR diverter
-TB & plenum
-RH side runner
-LH side runner, loosened only
But I had to deal with the pressure line leaking fuel for a while and then nearly cross threades the fitting on reassembly; the latter took an hour to unf--k... Now working on a leak at the 9th injector plumbing.
Without the fuel leaking issues I'd guess the job would have taken me around 3-4hrs.
Old Apr 22, 2008 | 08:26 PM
cv67's Avatar
cv67
St. Jude Donor '05
CFI
Old Apr 23, 2008 | 12:53 AM
the blur's Avatar
the blur
you will spend 3-4 hours scrapping gaskets... especially if it is the first time it's been apart. 20 yo gaskets need a single edge razor, patience, and a can of gasket remover. It's a full weekend job the 1st time around.
cleaning the plumen, runners, fuel rail.......
Old Apr 23, 2008 | 06:39 AM
Calderone's Avatar
Calderone
Why does it leak ? Bad O-Ring ? not enough torque ?
Old Apr 23, 2008 | 08:10 AM
bd2626's Avatar
bd2626
Depends on what you want to do? I did mine on a weekend but I took the time to clean and paint, replace anything I could while I was doing the injectors. There is even a write up here as to how to do them without removing the runners so it could be as little as 2-3 hrs...depends on how cold the beer is Just a word of advice...if this is the first time, mark everything clearly to help with re-installation and clean the plenum, tb and runners well.
Old Apr 23, 2008 | 08:15 AM
Calderone's Avatar
Calderone
Sorry to ask but .....what's a leaking injector ?
what's the symptoms?
Old Apr 23, 2008 | 08:58 AM
Livin the Dream's Avatar
Livin the Dream
I also put new O rings in the fuel rails. My actual RR time was 2-3 hours it took me longer cause I cleaned everything in sight
To Total time to replace injectors on L98??
Old Apr 23, 2008 | 09:04 AM
Calderone's Avatar
Calderone
C'MON ...what's a leaking injector
what happens
Old Apr 23, 2008 | 09:13 AM
Sam Lam's Avatar
Sam Lam
what happens
Have you experienced a leaking faucet in your apartment/house? You can see the water dripping from the nozzle with the water turned off. A leaking injector will leak fuel (under pressure) just as a faucet will leak water. If the leaking process happens during the operation of the engine, the ECM will have a difficult time controlling the air to fuel ratio and the car will run like crap!
Old Apr 23, 2008 | 09:23 AM
Kool88vette's Avatar
Kool88vette
I just replaced my injectors. I also rebuilt my fuel rails with new gaskets and O rings. I used duct tape to seal the injector and intake holes to keep stuff out of my engine. I installed a new fuel pressure gauge on the fuel rail. I rebuilt the fuel pressure regulator. I cleaned the throttle body I cleaned and polished everything.
I spent about 8 hrs on it. I believe we should forget about the time and do it right.
