need help with choosing the right gears for the setup i have planned
383 Miniram setup with AFR heads/long tubes to true duals no cats. Engine power is at the 3500-6000rpm. factory says that the engine with the AFR heads is dynoed at 489BHP. using my 4+3 trans what would be the best street gear to use in the D44 rear spinning the 17x10 wheels
