Doors unlocking on bumps
Old Apr 23, 2008 | 06:27 PM
ynk1121's Avatar
ynk1121
Default Doors unlocking on bumps
Every bump I go over the doors unlock. Is it safe to assume that the door jamb switches are the culprit? Should I just replace them or is there an easier way to diagnose the problem?
Old Apr 23, 2008 | 06:36 PM
Aurora40's Avatar
Aurora40
is the power lock switch loose or wobbly? Maybe it flips to "unlock" when jarred?
The door jamb switches, afaik, just tell the car if the door is closed (used for the interior lights and security system). I don't think they'd cause locking/unlocking.
Old Apr 23, 2008 | 06:40 PM
ynk1121's Avatar
ynk1121
Sorry. I've been here long enough that I should remember to include my year. It's a 95 convertible. When the key is in the ignition and the door closes it's supposed to unlock the door so you can't lock the keys inside. I was thinking maybe it thinks the doors are opening because of a bad switch...?
Old Apr 23, 2008 | 06:44 PM
ynk1121's Avatar
ynk1121
thx. I should check if the interior lights go on when it does it. It was too bright out today to notice if they did or not.
Old Apr 23, 2008 | 10:36 PM
94flavette's Avatar
94flavette
PKE issue?
Old Apr 24, 2008 | 02:23 AM
ynk1121's Avatar
ynk1121
Originally Posted by 94flavette
PKE issue?
Doesn't the pke system turn off when key is in the ignition?
Old Apr 24, 2008 | 09:44 AM
JJ2000's Avatar
JJ2000
where is the door jam switch located, mine sometimes sticks and inter light doesnt come on when you open the doors
Old Apr 25, 2008 | 12:18 AM
ynk1121's Avatar
ynk1121
About center in height towards the outside edge of the door.
To Doors unlocking on bumps
