On my 93 the front left brake caliper has a ton of play...at least double the right side. The pin is there and everything seems normal, but with the wheel off you can move the caliper around. Any idea?
which direction the play occurs in would be helpful.
Also, if the little ears on the pad are worn off a little around the pin (the ones that keep the caliper from sliding out from the bottom when the pin is in) that can cause play. If those little earsbecome too worn, the caliper has a tendancy to rip off of the bracket and tear the break line off.
Ask me how I know..
