Vacuum Hose Replacemnet
Old Apr 24, 2008 | 01:57 PM
IslandVette808's Avatar
IslandVette808
Default Vacuum Hose Replacemnet
Im just wondering what size rubber vacuum hose should I use to replace the fragile plastic ones that run under the plenum and to the EGR valve? Ive read in a post that they are prone to break and cause vacuum leaks so since Ill have the plenum and intake manifold off, I figure ill replace them with rubber ones. The local checkers has 5/32" and 7/32" sizes in stock. Thanks.
Old Apr 24, 2008 | 03:19 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I don't recall what size, but you can rule out 7/32". Buy an inch of the 5/32" and try it for size.
Old Apr 24, 2008 | 03:26 PM
86PACER's Avatar
86PACER
Take a piece into the store with you and trial fit some sizes.
Old Apr 24, 2008 | 11:10 PM
RACER 1993's Avatar
RACER 1993
The O.D. of the plastic tube should be what you need for I.D. on the hoses. Those plastic tubes look pretty durable to me though and they don't disentegrate like rubber. Some business near you that sells industrial tubing could probably fix you up with plastic tubing you could use.
To Vacuum Hose Replacemnet
