Ride Height Issue
Old Apr 24, 2008 | 02:31 PM
bjack78's Avatar
bjack78
Navigator
Default Ride Height Issue
I have an 86 convertible. Today I changed out the stock rims & tires to a set from a 93. I used the spacers and installed them correctly. I have an issue with the rear end now. The rear end LOOKS like there's a huge gap between the tire and the fender well. Is there any way to lower the rear end so everything sits right? Is this a common issue when switching wheel/tire combos or am I just being paranoid? Any help you guys could give would be greatly appreciated.
Old Apr 24, 2008 | 02:57 PM
JEFNLSA's Avatar
JEFNLSA
Drive it a bit and the rear should settle down some. If there's still too much wheel gap for your liking, you can adjust the rear spring bolts to lower the rear some...if it still sits too high, and there's no more thread left to adjust with, put in longer bolts.
If anything, the new/larger wheels should leave you w/ less gap..not more...so your problem, if any, is not the (new) wheels.
