[update] Engine rebuild
Old Dec 15, 2001 | 02:24 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: [update] Engine rebuild (JIMBO55)
CRAIG--NICE JOB, WHAT DID IT ALL COST?? ALSO WITH THE SLUDGE SHOWN ABOVE, IF YOU START TO USE MOBIL
1, WILL MOST OF THE ENGINE START TO BREAK UP THAT SLUDGE? JIMBO :U
Thanks! That was my old '85 motor, so it was a little cheaper to rebuild than newer motors. The block was not worn at all and the forged pistons were in great shape, so the machine shop just cleaned those up. All the other work was done.... New valve guides, valve job, all new valves, crank turned, new bearings-main-rod-cam, new oil pump, surface heads, new lifters, new pushrods, new hyd cam, etc. etc. etc.
I stayed under $1200 for the whole thing. It was still pretty much stock except for the mild cam. It ran 13.73 @ 100 when it was done.
Old Dec 15, 2001 | 02:43 PM
RocketSled's Avatar
RocketSled
Default Re: [update] Engine rebuild (Marcho Polo)
Here's some pics of _MY_ old motor...it's got 120,000 miles on it, always used a synthetic (occasionally Quakerstate), I bought the car at 85,000 miles and have driven the PANTS off it...
And the dirt I dropped down into the lifter valley :eek:
Old Dec 15, 2001 | 02:46 PM
GlockLT4's Avatar
GlockLT4
Default Re: [update] Engine rebuild (RocketSled)
Wow.. that looks a lot better than mine.... I'm really starting to wonder what the !@#$ the first owner did to my car!
Old Dec 15, 2001 | 02:56 PM
92corvette's Avatar
92corvette
Default Re: [update] Engine rebuild (Glock'94)
Check these out. At about 115K miles. Lousy pic, but I think you can get the idea. Clean as a whistle. All I had to do was wipe the oil off with a rag. Absolutely zero sludge. I guess the previous owners always used Mobil 1 and changed it frequently. I consider myself lucky.
Old Dec 15, 2001 | 05:21 PM
Marcho Polo
Former Moderator
Default Re: [update] Engine rebuild (92corvette)
Wow! That is one clean motor for the miles!!!!
Here is my '90 with 127,000 on the clock! The lifter valley is just as clean, I forgot to snap a pic with the intake off.
Old Dec 15, 2001 | 05:27 PM
92corvette's Avatar
92corvette
QUOTE]
[/QUOTE]
Don't ya love it Marcho? Goes to show that taking care of a car and regular maintenence really pays off in the long run. :cheers:
Old Dec 15, 2001 | 06:43 PM
CFI-EFI's Avatar
CFI-EFI
Yuck!!! I installed my ported intake in September. The valley was as clean as Rocketsled's (and others). Some slight darkening of metal. No varnish. No sludge. The manifold had never been off before. 140,000 miles and ONLY dino.
Old Dec 16, 2001 | 10:51 AM
No Go's Avatar
No Go
Default Re: [update] Engine rebuild (CFI-EFI)
I would attribute that sludge build up to lack of consistent oil changes rather to synthetic or dino oil.
If any consolation...I've seen much worse...
Old Dec 16, 2001 | 11:15 AM
Nathan Plemons's Avatar
Nathan Plemons
Ok, so mine only has 60k miles, but it's been synth from day 1.
Old Dec 16, 2001 | 11:55 AM
92corvette's Avatar
92corvette
Default Re: [update] Engine rebuild (Nathan Plemons)
Heck Nathan, only 60K...that's practially 'brand new' in this post. :) :)
It does look good inside.
I've noticed that knowing the inside of my engine is that clean gives me the
confidence to put the hammer down a little harder without worrying that
something might break. :D :D
