Which OBD terminal...pictures
Old Apr 25, 2008 | 05:02 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Which OBD terminal...pictures
I finished the front suspension, headers and MSD Opti. I'm having an issue that did not have in the last three days running the engine. The engine starts good and idles for 1-2 minutes then, the fans go on (not hot) and the 'service engine soon" light comes up. The only that happened different was today, I left the ignition on and the battery died. Did that brake anything?
To retract that code which terminals do I "Jump"
Old Apr 25, 2008 | 05:57 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Anyone?
Old Apr 25, 2008 | 06:36 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
It is an OBDII connector, but your system is OBDI. If you do a search on PCOLT94, he described what pins you connect to pull the codes.
Old Apr 25, 2008 | 08:17 PM
PLRX's Avatar
PLRX
2017 C4 of Year
pcolt94, thanks
To Which OBD terminal...pictures
