c5 wheels on c4 question
Old Apr 27, 2008 | 12:57 PM
F0RMULA's Avatar
F0RMULA
Default c5 wheels on c4 question
i have a set of 1999 C5 chrome wheels i want to but on my 87.
do i need spacers, or some kit or anything?
what will happen if i just put them on without that?
Old Apr 27, 2008 | 05:05 PM
ZD1's Avatar
ZD1
Not sure if there is a wheels'' section...but if your car originally came with the 16" wheels then you'll need a spacer. Go to vettebrakes.... What you need to find out is your stock offset to the wheels offset.
The other thing you should know is that most people believe that since the bolt pattern of the C5/6 is different (metric vs standard), that wheels should not be inter change. Most people that run c5/c6 wheels, like my self don't have problems.
Old Apr 27, 2008 | 05:55 PM
racebum's Avatar
racebum
You will need spacers on an 87, the offset changed when the new suspension went in the c4 in 1988. the 99 wheels will bolt right on but they use an offset in the 50 something range versus your 30 something offset. i use to know the exact numbers but this age stuff is killing me, i turned 30 the other day and forgot half of what i use to know
Old Apr 27, 2008 | 06:40 PM
BAM92's Avatar
BAM92
Just buy some 1" adaptors all around and you will be fine.
To c5 wheels on c4 question
