Engine oil 1qt overfill
Old Dec 15, 2001 | 12:07 PM
TPFKATK's Avatar
TPFKATK
Default Engine oil 1qt overfill
The local chevy dealer put 6 qts of oil instead of 5 in my vette. It's been driven about 5 miles this way. Think there is any damage?
Harold
Old Dec 15, 2001 | 01:29 PM
c4cruiser's Avatar
c4cruiser
Default Re: Engine oil 1qt overfill (TPFKATK)
Did they tell you that they overfilled it? Does the oil level on the dipstick show above the line on the dipstick? If it is a quart over and you only drove it few miles, there should be no real harm done, but I wouldn't leave it a quart over.
I would first go back to the dealer and have them re-do the oill change. They should have known what the correct amount was to put in. That's assuming the "technician" can tell the difference between the numbers 5 and 6.
If you can't get back to the dealer, you may want to remove the oil filter and replace it with a new one. The filter should contain about 1/2 quart and bring the level down to where it should be OK. Have the engine warm and let it idle until the pressure gauge shows a normal reading.
Old Dec 15, 2001 | 02:09 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Engine oil 1qt overfill (c4cruiser)
There's not much damage an extra quart will do.
I wouldn't worry about it at all.
Transmission a quart over I'd worry about.... engine "no worries".
Both my Vettes will use about 1/4 of quart between 3000 mile oil changes.
I typically overfill them that 1/4 quart so they are normally sitting at the full level when it's time for the oil change.
Don't worry about it, there's nothing it's going to hurt.
Old Dec 15, 2001 | 05:31 PM
jpee's Avatar
jpee
Default Re: Engine oil 1qt overfill (VetNutJim)
Here's another thought..
Every time you check the oil you remove a little when you wipe the dip stick.
So lets say 20 times you check the oil you remove app 1 oz of oil... 32 oz in a qt.
32x20 = 640 so just check your oil 640 times & it should be ok :D
Old Dec 15, 2001 | 11:31 PM
Vic'89's Avatar
Vic'89
The quickest and easiest way is to remove the oil filter and install a new one.
But , I would go back to the dealer and tell them to do another oil change because they messed it up.
Vic
Old Dec 15, 2001 | 11:44 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Engine oil 1qt overfill (Red96Coupe)
Panuzzo been reading the C5 froums too much !!!!! :crazy:
Old Dec 16, 2001 | 01:14 AM
jpee's Avatar
jpee
Default Re: Engine oil 1qt overfill (PeteL)
Ya right.. if I go there too much I get nuts... and start thinking about ZAINO instead of 60' times :D
Old Dec 16, 2001 | 01:28 AM
jfb's Avatar
jfb
If they installed a new oil filter, it takes about 3/4 qt and you are over by only 1/4 qt. Even if they didn't install a new filter, 1 qt overfill won't hurt. Overfilling is damaging only when the oil level is so high that the crank hits oil which stresses the crank and worse, foams the oil. Foamed oil delivered to bearings means no more bearings. One quart won't do it. I would siphon a qt out of the dipstick tube. When I change my oil, I fill the oil filter too , then install it, but I have never heard of any commercial places that do this. I don't want my engine turning without oil being pumped.
Old Dec 21, 2001 | 10:46 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Old Dec 22, 2001 | 02:21 PM
LT-IV's Avatar
LT-IV
Default Re: Engine oil 1qt overfill (mackeyred96)
Chevrolet used to recommend that you put an extra quart of oil in the LT4's.
Before anyone flames me I need to state that it was for auto-x or high speed turns etc. For normal street driving it was not necessary.
Seems that the higher revving LT4 combined with the cornering abilities of the C4 chassis could contribute to an oil starvation problem.
So, the good news is that wont hurt the engine. :)
The bad news is that you need to find a different service technician. :mad
Old Dec 22, 2001 | 02:27 PM
scorp508's Avatar
scorp508
Did they change the filter also? If they didn't you are actually 1.5qts over.
To Engine oil 1qt overfill
