Help Removing Intake Runners??
Old Apr 28, 2008 | 08:42 PM
Brett Richmond's Avatar
Brett Richmond
Default Help Removing Intake Runners??
I have all the upper bolts and one of the 2 on the inside of the runners. My question is how do you get the bolt out that is located at the back drivers of the intake when the fuel rail is still in the way?? Any ideas as I can not reach this last bolt easily??
Old Apr 28, 2008 | 08:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Think I had to use a 1/4 in extension and a wobbly. You mean the one in front?
Old Apr 28, 2008 | 08:55 PM
Brett Richmond
The one at the back of the intake near the firewall and distributer.
Old Apr 28, 2008 | 09:07 PM
Stewball's Avatar
Stewball
I've been taking mine off and on this weekend for an injector change. I used a flex extension and a short T40. For the front one on the top of the manifold I removed the vacuum lines and electrical connector by taking out the thermostat bolt. This allows you to get a T40 without an extension on it.
This is on my 87.
Old Apr 28, 2008 | 09:32 PM
Brett Richmond
This is on my 87.
I got that one out easily enough, I am now working on the back one same side.
Old Apr 28, 2008 | 10:12 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
It was easier if I popped the fuel rail up,or removed the distributor from the intake.Gave me alot of room either way.I removed alot of distibutors over the years before so It was easy to remove and reinstall and set the timing again for me.If you never done this,you may want to steer clear of doing that for now.
The fuel rail is bolted to the front of the intake with 2 torx bolts as well as the 4 small 10MM ones on top.Those have to come loose to lift the rail off some.
I needed to use a large screw driver or pry bar to pop the rail off the holes of the intake.They get a bit stuck in there over the years.Relube the injector lower O rings on there if you lift the rail off and the O rings arent damaged.Replace if they are oblong and damaged.That aids in ease of install back down.
Ive heard of people using smaller 1/4 inch extensions and other smaller torx sockets but I never had much luck with that,with the other stuff in the way.It can be done though,but very tight back there.
Old Apr 29, 2008 | 04:28 AM
65Z01's Avatar
65Z01
My question is how do you get the bolt out that is located at the back drivers of the intake ...
I remove the EGR tube and use a narrow torx head on a 3/8" extension to easily access that bolt.
Old Apr 29, 2008 | 07:47 AM
jmrl98's Avatar
jmrl98
Gotta use an extension - I'm ready for something a tad more simple, as even though when you do it enough it is second nature, it becomes a nuisance.
Old Apr 29, 2008 | 10:15 AM
bd2626's Avatar
bd2626
After the plenum, I removed the passenger side runners because the inside bolt was easy to get to. Then I took off the fuel rail which made it much easier to get to the inside bolt on the drivers side, with a universal adapter which allows for a good angle you should be able to get the drivers side one now!
Old May 6, 2008 | 01:16 AM
Sam Lam's Avatar
Sam Lam
Brett:
If you have removed the plenum, you can remove both fuel rails AFTER you remove the EGR valve and crossover pipes. The passenger fuel rail has two #40 Torx bolts that secure it to the intake. Then, remove the crossover pipes and both fuel rails can be lifted out. This give you easy access to the inside runner bolts. I am removing the runners on my 89 at this time to install a set that is not dented. Hope this is helpful.
To Help Removing Intake Runners??
