26mm Rear Sway Bar...how do I ...?
Old Apr 29, 2008 | 12:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default 26mm Rear Sway Bar...how do I ...?
I'm installing VBP rear suspension, for the rear 26mm sway bar, the mounting brackets to the frame (2), there is an opening for me to slide the sway bar in.
Once mounted, this "opening" goes toward the front or the rear of the Vette?
Old Apr 29, 2008 | 02:16 PM
racebum's Avatar
racebum
take a picture when you get a minute, usually those things will mount either direction. should be able to eyeball which way it fits...think legos.
Old Apr 29, 2008 | 03:02 PM
PLRX's Avatar
PLRX
2017 C4 of Year
There is simetry on both sides not like the front (one side wider)
Sorry, can't take picture, cable, download etc. I use the neighbor's Wi-Fi and I get a "very low" signal
I'm documenting everything after May 15, I'll be able to download lots of pictures oh my VBP project
Old Apr 29, 2008 | 07:28 PM
racebum's Avatar
racebum
oh now i remember what you are talking about, they should only fit one way. remember if you get into trouble, call VBP, they have pretty nice tech support. i had some issues with one of those adjustable front springs, the issue was the car sat on the ground LOL. anyway with some thicker adjustment pads i can raise the car to a decent ride height.
To 26mm Rear Sway Bar...how do I ...?
