Fuel injector cleaning
Old Apr 29, 2008 | 02:36 PM
Expsd's Avatar
Expsd
Default Fuel injector cleaning
My 91 has 19,970 and idles a little rough. I have changed the plugs, wires, etc. and was thinking of cleaning the injectors. Now today I was in Walmart, killing time while my wife shopped and was talking to the auto service manager. He seemed pretty sharp, had, and still ownes sports cars. I saw a sign for $19.95 injector cleaner by a well recognized name that I forgot. I asked the manager if he would use it on one of his cares and he said yes. Anybody heard anything about this? Please no:
You get what you pay for
What do you expect the manager to say
Why Walmart
Thanks in advance for your comments
Old Apr 29, 2008 | 03:09 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Seafoam 1/2 can though an intake vacuum line the other 1/2 in the tank.
Old Apr 29, 2008 | 03:19 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Default do not use ANY fuel injector cleaner in a multec
The 89-94 multecs are not alcohol complient. There is a epidemic of multec failure going on right now. It has been attributed to the alcohol and or Ethonol additives in the fuel and can cleaners. The alcohol is breaking down the seal that separates the fuel orfice and the coil housing causing liquid to penetrate the coil and accelerating the failure of the injector. GM has recommended not to use these additives in these years. However the gas companies continue to add ethonol in the fuel. Either e10 or e15 contains enough ethonol to cause this problem. Unfortunatlly, all states will have at least E10 shortly.
Old Apr 29, 2008 | 03:56 PM
skybolt31's Avatar
skybolt31
I have a can of 3M cleaner that connects to the fuel rail with a hose, I emailed 3M and they assured me that it was compatible with ALL injectors. I am not quite convinced that it won't harm anything, so unless I feel like my injectors are so bad I have nothing to loose, it sits on the shelf.
Old Apr 29, 2008 | 04:01 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I believe that is the cleaner that GM dealerships use on their injector cleaning service.
Old Apr 29, 2008 | 04:06 PM
BADDUCK's Avatar
BADDUCK
Why Walmart
I have 52K on mine and they are fine. You might also check your fuel filter, mine was partially clogged. You can OHM out your injectors to see if one or more are weak.
Old Apr 29, 2008 | 04:07 PM
FICINJECTORS
Supporting Vendor
this is from an AC delco service bullitenate: June 3, 2005 Bulletin Number: 05D-J-105
To: All Distributors and Jobbers Category: Service
From: Stephen Sigg, Product Service Line(s): 10, 21
Multec I: Pre-1994 Multec I injectors should not be cleaned, and no additives are
recommended. These are wet-coil injectors with deposit-control tips. Multec I injectors built
after 1994 are wet coil injectors with deposit control, but because of internal changes, these
injectors can be cleaned, and an additive can be used to prevent deposit buildup. There is a
GM bulletin with the proper procedures and precautions for cleaning these injectors.
Old Apr 29, 2008 | 04:20 PM
guido7834's Avatar
guido7834
Just had my injectors cleaned and fuel filter replaced on my 87. what a difference. Much better response and feels like more power. Don't know when the previous owner had it done (if at all) but I had run injector cleaners through the fuel system and no results like this.
Old Apr 29, 2008 | 04:29 PM
FICINJECTORS
Supporting Vendor
87's are cleaned all the time. They are Bosch or Lucas injectors like the ones in the video on another thread we just put up. The Mutec injectors used 88-94 are the ones that should not have cleaning fluid run through them.
Old Apr 29, 2008 | 04:47 PM
corvette85guy's Avatar
corvette85guy
I'm in agreement with REDEASYSPORT.
A half of can of SeaFoam through the brake booster vacuum line and the other half of can in the as tank fixed me right up.
I was shocked on how well it worked!
Old Apr 29, 2008 | 05:32 PM
skybolt31's Avatar
skybolt31
Not to argue with your results, but would putting something in through a vacuum line have any effect on the injectors? It would be going through the intake tract and passing by the end of the injectors, not passing through them. It doesn't seem to me that you could clean an injector that way.
Old Apr 29, 2008 | 09:01 PM
guido7834's Avatar
guido7834
I agree with skybolt, I would think it would clean carbon out of the cylinder?
Old Apr 29, 2008 | 09:42 PM
Redeasysport
The purpose of the 1/2 can of Seafoam in the intake IS to clean it. It does get nasty in there. It cleans the valves too.The other half goes in the tank for the injectors. When you get it done at a shop the do the same thing if you watch one can goes into the intake and they add another to the gas.
To Fuel injector cleaning
