85 digi-dasn question
Old Apr 29, 2008 | 10:19 PM
Muffin's Avatar
Muffin
Default 85 digi-dasn question
Got her back together and out of the garage. Had almost forgot how much fun she is. One glitch:with the headlights on the right turn arrow stays lit. With the lights off the right turn blinker is very,very slow but functions.Anyone have a clue that may save me hours of troubleshooting?
Old Apr 29, 2008 | 10:21 PM
viii's Avatar
viii
This might help
http://www.batee.com/corvette/dcrg/index.shtml
Old Apr 29, 2008 | 10:59 PM
jhammons01's Avatar
jhammons01
that sounds like you might have a light bulb out.......check to see if all the bulbs are blinking.
The circuit heats up and the relay opens........then the relay cools off and closes completing a circuit, then it all starts over again.
Old Apr 29, 2008 | 11:53 PM
jfb's Avatar
jfb
Your problem is a poor ground or an open ground on the right front park/turn signal lamp. Check the black ground wire from that socket, it first goes to a splice in the wiring harness and then to a ground on the frame just behind the lamp. I would check the condition of the frame ground. This poor ground causes both of your problems.
Old Apr 30, 2008 | 08:19 AM
Muffin's Avatar
Muffin
What I was looking for. Thanks.
To 85 digi-dasn question
