Bad brake booster?
Old Apr 30, 2008 | 10:16 AM
carriker's Avatar
carriker
Default Bad brake booster?
Can anyone tell me the symptoms of a bad brake booster? I am having problems in my vette and I want to be sure it's the brake booster before I buy a new one. I'm looking for people with C4s who have had to replace the booster, what were the signs? Thanks in advance CF!
-Matt Carriker
Old Apr 30, 2008 | 12:20 PM
jhammons01's Avatar
jhammons01
Why don't you tell us what you are experiencing that leads you to believe your booster is bad.
No Booster, Hard pedal.......broken down to the lowest element.
Old Apr 30, 2008 | 12:39 PM
carriker's Avatar
carriker
Very hard pedal. Hissing noise from under dash whenever I push the pedal in. How much do new brake boosters run? Will local auto parts store be able to order me one? Thanks.
-Matt Carriker
Old Apr 30, 2008 | 12:42 PM
jhammons01's Avatar
jhammons01
Sounds like the thing is leaking......the hiss the vacuum from the motor.
I am not sure, but I think this is a standard GM booster that many parts stores carry.
I've enjoyed being able to find tons of GM replacement parts for my C4 at local parts stores.
Old Apr 30, 2008 | 12:45 PM
jhammons01's Avatar
jhammons01
Kragen has them for $129
http://www.partsamerica.com/ProductD...Number=5471405
Old Apr 30, 2008 | 12:49 PM
carriker's Avatar
carriker
Cool thanks. Do you know how long it takes to replace a brake booster? I've never done that before.
Old Apr 30, 2008 | 01:03 PM
jhammons01's Avatar
jhammons01
I am not sure if I am fortunate or "un" fortunate, but I never had to replace one.
There are threads I've read where guys talk about having to lie on their backs with feet up in the seat to get to certain things....then one guy said He took his seat out.....but I don't know where that thread is. it was about 5 months ago I was reading it.
Old Apr 30, 2008 | 02:27 PM
Lichen's Avatar
Lichen
Try to avoid the Cardone brand. They are really crappy. Spend $100 more and get an OEM (PBR brand) booster. Replacing it can be a PIA, but it is pretty straigtforward (do a search).
Old Apr 30, 2008 | 02:34 PM
jhammons01's Avatar
jhammons01
Everyone says that about Cardone or Car Done.....
I guess there is some truth to it.......I personally do not know either way.
Old Apr 30, 2008 | 03:24 PM
rayharperuk's Avatar
rayharperuk
It took me 2 hours to replace my booster. Easier if you remove the drivers seat. The main problem is the left side nut that holds the booster in place. Impossible to get a 1/2 inch drive socket onto it. You will need a 3/8 drive and some extension bars to get at it properly. When putting this particular nut back on place some grease over the stud and the nut to keep it in place while you carefully turn it. My original plastic PBR had a large fracture at the bottom of the booster probably caused by the header. My new one is an aftermarked one made of metal. I had to adjust the brake light switch afterwards as the new booster had a slightly different pedal travel otherwise it was OK
Old May 1, 2008 | 07:36 AM
Da Mail Man's Avatar
Da Mail Man
-Matt Carriker
....ohhh yeah, booster or vaccum check valve is history...
Old May 1, 2008 | 09:39 AM
Strick's Avatar
Strick
One of the main reasons the booster fails is a leaking master cylinder. You won't know until you remove the booster. You can buy a loaded set up which has the master cylinder along with the booster. Your FSM has good instructions on this.
Old May 1, 2008 | 10:34 AM
rick lambert's Avatar
rick lambert
Took me just over an hour, I didn't remove the drivers seat but you have to be somewhat of a contorsionist. Little secret, put a piece of masking tape on your socket, helps keep the nuts from falling into some hard to get at areas. I don't remember the brand, but I'd recommend getting a metal one rather than the standard plastic ones.
Old May 1, 2008 | 03:41 PM
86PACER's Avatar
86PACER
Get a metal booster. They won't crank or melt like the factory one.
Old May 4, 2008 | 12:38 PM
carriker's Avatar
carriker
I bought a new brake booster. Installed it, and brakes work like new again. Thanks corvetteforum for all the help! It took me longer than expected to install it, but I took a lot of breaks because it was HOT outside. Thanks again.
-Matt Carriker
Old May 4, 2008 | 09:21 PM
Da Mail Man
To Bad brake booster?
