bad idle at stop lights...
Old Apr 30, 2008 | 11:42 AM
derek 91 vette's Avatar
derek 91 vette
Default bad idle at stop lights...
1991 L98 26,550 miles... It seems like a misfire.
I changed the plugs,wires,cap,rotor,gas filter and module. It still has a intermittent spark issue? It shakes and surges only when its hot. (in drive at an idle) No problem WOT. It does the same thing in park or neutral. But its more noticeable in drive. I Checked the timing. Good.
My friend pulled each wire off while at an idle in drive. He said sometimes there was no difference when he pulled the wire off.
Whats left the coil?
this is a pain in the ***.
any help would be greatly appreciated thank you.
Old Apr 30, 2008 | 11:48 AM
erd90vettesc's Avatar
erd90vettesc
It is your lovely Multec Fuel Injectors. Mine is doing the exact same thing and I am getting ready to replace them so i can enjoy my car this summer. My car has 90k on it so you can imagine how bad it is. It has actually died a couple of times. My suggestion would be to OHM them out to see how bad they are.
Old Apr 30, 2008 | 02:26 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Same problem here. I beleive it to be the injectors.
Old Apr 30, 2008 | 02:58 PM
jspeakman17's Avatar
jspeakman17
Default problem?
i am going the same thing here! ive done the cap, rotor, plugs, wires, and coil, and ive checked for vaccuum leaks. ive been told to check and clean the Idle Air Control, so thats next on my list. im gonna also check the injectors because it seems to be the consensus on this page! you are not alone!
Old Apr 30, 2008 | 03:03 PM
erd90vettesc
What years are the other cars on this page, the Multec injector plague was supposedly on the 90 and 91 model years. Would be interesting to know.
Old May 1, 2008 | 12:50 AM
jspeakman17
mine is a 89 with 105k and runs like a CHAMP, but in drive, after it warms up, the idle fluctuates from 500 to 700 rpms, kind of pulsating. tomorrow im gonna check for engine codes and go from there. Next on the list, assuming no codes, are Idle Air Control and prayers!
Old May 1, 2008 | 12:54 AM
Master__Shake_'s Avatar
Master__Shake_
Does it idle okay when cold or is it rough too? Usually when it misfires after warmed up it's the injectors - I'd bet my money on it. If it does when cold too, however, it may be a different animal altogether.
Old May 1, 2008 | 02:43 AM
derek 91 vette
I took it to mechanic. He said its definitely the injectors. Where can I get some injectors?
Old May 1, 2008 | 02:49 AM
beurling's Avatar
beurling
Cruising
just changed injectors on mine
much better
mind you mine still has a slight m isfire but this is probably due to other issues as shes been sat for 3.5 yrs
good luck
Old May 1, 2008 | 05:57 AM
Weav's Vet's Avatar
Weav's Vet
http://forums.corvetteforum.com/show....php?t=2011356
http://fuelinjectorconnection.com/shop/
Old May 1, 2008 | 02:57 PM
jspeakman17
Default injectors? ? ?
mine idles great until it warms up and the idle settles below 800 rpms. than at stop lights, the fun begins. it is embarring because my vette is SUPER CLEAN and sounds mean with exhaust, then at the light the miss is ugly! is this a common problem? can i test the injectors? if the are bad, what are some upgraded injectors youd recommend? thanks!
To bad idle at stop lights...
