Need a Tune for my 95
Old Apr 30, 2008 | 12:47 PM
TON12350's Avatar
TON12350
Default Need a Tune for my 95
Does anyone know a good place to get your computer retuned in the NY/NJ area? I do not want to do a mail order retune and the vette doctors do NOT retune C4's, only C5's & 6's. Any suggestions?
Old Apr 30, 2008 | 01:32 PM
rickneworleansla's Avatar
rickneworleansla
What about an email tune and upload it yourself with a laptop and cable? That's how I did my 95. (PCMFORLESS) I guess your looking for a custom dyno tune though. Expect to pay about $500 or so.
Old Apr 30, 2008 | 02:51 PM
TON12350's Avatar
TON12350
I figured it was going to cost that much...It seems like no tuners wants to spend time tuning 94,95, & 96 vettes...guess we are out of luck when it comes down to custom dyno tuning
Old Apr 30, 2008 | 03:37 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I believe HPtuners and EFILive both have the software to tune your car. You could buy the software and install it on a laptop then take it to a good dyno shop and have them tune it. Then you'd have the software if you want to play around with it yourself or if you change things later.
Old Apr 30, 2008 | 03:48 PM
rickneworleansla
I'm using Datamaster TTS to log data and TunerCat software for tuning on my 95 with a USB to OBD II conector cable from Moates.net. The software is available in trial versions if you already have a laptop and want to try it out. You would still need the $80 USB/OBD cable and the $20 software definition file. If tuning you may also want a WBO2 sensor which can get expensive. I'm looking for a way to tie the WBO2 sensor into the PCM to log data with Datamaster instead of having to buy the seperate reader.
Tunercat Screens
Datamaster screen from a track run in 07. I had throttle cable issues. Notice the %TPS.
To Need a Tune for my 95
