Overheating
Old Apr 30, 2008 | 01:03 PM
devilfish's Avatar
devilfish
Default Overheating
I started up the car today for the first time after the winter.
I let the car idle for about 10 min.
Then the car started to boil due to air in the coolant system.
I could se water and steam come out from the t-stat housing, and rear of the intake from the gasget area (where the coolant hoses goes for the converted lt1 intake).
And I could also hear it boil in the radiator.
My first thought where that now need to replace the intake gasget.
BUT after I mange to get all the air out, and then re-torqued the intake bolts ( just to be sure ), I cant se any leaks, and the coolant level does not decrease.
Im I just lucky, or should I repalce the gasget anyways?
Old Apr 30, 2008 | 01:05 PM
jhammons01's Avatar
jhammons01
^^yeah, that shouldn't happen. Something dried up there and became brittle.
Your coolant system is nothing to sneeze at or take lightly. I'd pull that Thermostat as well.
Old Apr 30, 2008 | 01:20 PM
devilfish's Avatar
devilfish
Yeah. I changed the t-stat and gasget. I have not chagned the intakegasget yet.
Right now I have test drive the car, and no more overheating. ANd no steam/water is leaking.
But perhaps Its bet to replace that intakegasget anyways
Old Apr 30, 2008 | 01:59 PM
Square's Avatar
Square
Did you "burp" and "pack" your radiator?
My 86' would always look like the radiator was full, but I would get a "Low Coolant" light. I followed the "Burp & Pack" procedure in the C4 tech notes section here and that fixed me right up.
Old Apr 30, 2008 | 02:05 PM
devilfish's Avatar
devilfish
Yes m8. I followed the procedure as posted here. And now the temp is stabel. Im just worried about the intake gasget. But so far it seems to keep tight. I cross my fingers...
Old Apr 30, 2008 | 03:35 PM
KoBrah1's Avatar
KoBrah1
You need to change the oil and filter too, just in case coolant entered the oil.
Jake
Old Apr 30, 2008 | 04:11 PM
devilfish's Avatar
devilfish
mm. your probaly right. But I cant se any water in the oil.. Well as long as dont need to change the intake gasget im a happy guy
To Overheating
