Passenger side window stopped working :(
Old Dec 15, 2001 | 09:04 PM
Kevin McGrade's Avatar
Kevin McGrade
Default Passenger side window stopped working :(
Where do i begin :confused:
Old Dec 15, 2001 | 10:16 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Passenger side window stopped working :( (Kevin McGrade)
Check to see if the bolt that holds the trim piece you pull to close the door is in place. My door handle bolt popped out and my window died. Turns out this is the ground for the motor.
Old Dec 15, 2001 | 10:18 PM
92TripleBlack
Gotta help a fellow 92 all black vette owning hockey player like myself! :cheers:
Old Dec 15, 2001 | 10:38 PM
Mark85Vett's Avatar
Mark85Vett
Default Re: Passenger side window stopped working :( (92TripleBlack)
Kevin,
You have mail......
Old Dec 15, 2001 | 10:39 PM
vader86's Avatar
vader86
possible bad regulator, or the plastic strip inside has broken.
Old Dec 15, 2001 | 10:46 PM
Kevin McGrade
That may be the problem, the handle has separated from the door on the top. I will check it out tomorrow.
Old Dec 15, 2001 | 11:59 PM
92TripleBlack
Bingo. I inadvertantly fixed mine by taking the pannel apart, not finding out what was wrong, then putting it back together. Figured while I was at it I'd fix that loose handle at least. Then it worked. So I tested it and low and behold it wouldn't work without the screw and would with it.
Luck :cheers:
Old Dec 16, 2001 | 10:51 AM
Kevin McGrade
Well that was hit!!! I have the handle a little tap and the window stated working again
Thanks everybody :cheers:
To Passenger side window stopped working :(
