1984 Corvette Removing Crossfire
Old Apr 30, 2008 | 11:27 PM
fettsvette84's Avatar
fettsvette84
Default 1984 Corvette Removing Crossfire
Is there a good way to upgrade this engine? If I removed the crossfire injection system and that crappy intake manifold, how much work would it be to install a more modern system? Would I have to get a new PCM? Would it fit? Do the LS crate engines fit? This engine needs to be improved!
Old Apr 30, 2008 | 11:48 PM
wayne lowry's Avatar
wayne lowry
What are you trying to do ? If you want more power then o.k. not a problem you can mod the crossfire you have. There is one guy on here
with an ALMOST stock 84 that is in the 13s with very little money in it.
Don't buy into the crossfire is junk bull****, I don't have one so I am not biassed but it's a s.b.c. with a misunderstood fuel injection set up is all it is. I think a crossfire that was solidly into the 12s would be really cool as MOST Corvette past or present aren't that quick.
Old May 1, 2008 | 04:34 AM
xrcrx's Avatar
xrcrx
My dead stock Crossfire ran 15.3@88. Ported Crossfire intake, 1.6-1 rockers K&N Filter and the cold air mod(makes the underhood ductwork functional got my 110k+ mile car to 14.3@96. A torque converter woulda got me 13's. The Dart heads and Crane 2040 did do it. That is all without modding the ECM! Don't waste money on Chips for the 84, they are just snake oil.
Old May 1, 2008 | 07:21 AM
JLeatherman's Avatar
JLeatherman
An LS can be made to fit, but it's a LOT of work. Do a search for the LSx swap threads.
The '84 wiring harness doesn't support a TPI system. To run a TPI from an 85-91 vette you'd need to completely change the harness and the ECM. The easiest way to get TPI onto an '84 is to purchase a complete standalone system like the Holley Commander or the FIRST. Pricey.
Turns out that most people who complain about the '84s lack of power don't have a good running '84 to start with. It isn't hard to tune up the crossfire. A few evenings of porting on the manifold and it's easily running with stock TPI vettes. A good head/cam package, ported manifold, AFPR, and a re-tune and they're really quite quick.
Does anyone have the writeup of Dominic's '84 that was in CF a while back? I remember seeing it posted in .pdf form before. This guy needs to read it.
Old May 1, 2008 | 12:57 PM
fettsvette84
Default crossfire
Ok...it is pretty much junk considering it's a 5.7L engine getting 205 hp. It's got over 100,000 miles on it so it's not even getting that. I would like to be at 300 hp. I think that's a good solid number for this car. Could I achieve that just by getting a tune up and tweaking the crossfire system?
Old May 1, 2008 | 01:18 PM
anesthes's Avatar
anesthes
Crossfire is garbage.
Get some alum heads, short duration cam, the new edelbrock intake or a HSR, and go 12s.
-- Joe
Old May 1, 2008 | 03:14 PM
wayne lowry
-- Joe
Garbage compared to what ??
The o.p. should sell the 84 and buy a LT1 car if 300chp is his goal and problem solved.
Old May 1, 2008 | 03:26 PM
anesthes's Avatar
anesthes
Won't disagree with you on that one!
Garbage compared to even TPI. Don't get me wrong, I like TBI on my k2500 truck, but the dual tbi (crossfire) on the fbody and ybody was horrible.
-- Joe
Old May 2, 2008 | 10:21 AM
fettsvette84
How much work would it be to install the Commander 950 Multi-Port Fuel Injection System from Holley? Does everything drop into place, or are there a lot of modifications required?
Old May 2, 2008 | 10:34 AM
CAJUN C4's Avatar
CAJUN C4
My LT1 Beater has the Following:
X-Ram Intake System see www.x-ram.com
"133" L-98 D-Port Heads (11;1 CR),ZZ4 Roller Cam,1:6 Roller Rockers,
750 CFM Bored Throttle Bodies, 8746 ECM and other goodies.
Good for at least 100+ H.P.
Old May 2, 2008 | 11:22 AM
CFI-EFI's Avatar
CFI-EFI
Now there is a man that LOVES his Crossfire. Even with that "U" turn, aftermarket, intake manifold, that is a lot of retrofitting to do to an LT1 engine. Most people UPgrade rather than retro grade. I wonder how that set up would work on an LS1, LS2, or LS7, engine?
RACE ON!!!
Old May 2, 2008 | 12:25 PM
Rohn's Avatar
Rohn
I replaced my CF induction(1984) with a Holley TBI Projection manifold and a 7.4L GM TBI unit. A pretty straightforward swap. 7.4L TBI unit may be overkill for you. A smaller GM unit may suffice.
I think the XRam is not a U turn it is better described as a Z turn! I had one so I can comment.
Old May 2, 2008 | 02:12 PM
anesthes's Avatar
anesthes
I used to run the singleplane manifold and TB on my firebird, but that would't fit under a vette hood. There are a lot of options and intakes.
You can use the factory harness and repin it to a new ECM. You'll lose some dash functionality though.
-- Joe
Old May 2, 2008 | 03:29 PM
fettsvette84
I'm just looking for some sort of gauge. This car has over 100k miles on it. Typically, what kind of wear and tear should I be looking at on this powertrain? In other words, what are the typical problems associated with this engine at that age? Should I be expecting to purchase new gaskets, rings, plumbing, etc. before I invest money to improve horsepower?
Old May 2, 2008 | 07:13 PM
Brimis's Avatar
Brimis
Sell your 84 and buy a Corvette that will provide you with the horsepower your looking for and your issues will be solved. My 84 has 170,000 miles and I just broke into the 14's with a stock engine, stall converter and street tires.
I'm tired of hearing/reading about the crossfire. If you don't like, sell it.
Anyone living in Jersey or near by and wants to take my car for a run, let me know.
Old May 2, 2008 | 07:57 PM
elkabong's Avatar
elkabong
Amen!
I keep my 84 around because of the "Crossfire is garbage" comments. I will be the first to admit that I went to the extreme and I am still working on it. "Crossfire is crap" just motivates me.
Oh by the way - I dont think the Holley commander will fit under the hood of a 84. You may want to look at that first.
I am headed to the track tonight to see if my parallel plumbing of the TBs works. If it does then I will head to the dyno. If not it is time to regroup and think of something else.
Old May 2, 2008 | 08:04 PM
NitrousSam's Avatar
NitrousSam
What is your budget to achieve your 300 horsepower?
To 1984 Corvette Removing Crossfire
Old May 2, 2008 | 09:27 PM
1985 Corvette's Avatar
1985 Corvette
Believe it or not, I'd get more satisfaction out of keeping the Crossfire and using my head to get around the setbacks and wring out the power from it. It's possible, you just need patience, planning and know-how. There's plenty on here, who have already got their hands dirty with the TBI modding and have really done a lot of work and research for you that you can actually apply to your car.
I don't believe in the "cross fire is garbage" mentality, rather much like the 4+3 it's a misunderstood red headed stepchild of the Corvette world.
Old May 3, 2008 | 08:45 AM
856SPEED's Avatar
856SPEED
How long have you owned the car? It seems like you bought a vehicle then realized you are not happy with the performance after $$ was exchanged. What were your expectations after purchasing it prior to buying it? I am assuming you test drove it first?? If you wanted a 300 hp car, then................
Old May 3, 2008 | 09:48 AM
qws's Avatar
qws
CFI can be a very reliable set up. I have two 84's. One thats modded and 1 thats stock. Our stock 84 has 219k on it and still runs and looks new.
Decide your goals/budget then go from there with any mods you do. They are many free mods out there if you look and do your research. Many crossfire owners went through just what you are in the beginning... then before you know your caught up in the crossfire... just like myself. Whether it is a low mileage,high mileage car you can make it a fun ride for yourself.
http://www.crossfire.homeip.net
