95 Lt1 Fuel Pump Relay Location?
Old May 1, 2008 | 04:07 PM
Mlo's Avatar
Mlo
Default 95 Lt1 Fuel Pump Relay Location?
Just wanted to make sure if the Fuel Pump Relay is really located under the passanger side dash?
Thanks,
Michael
Old May 1, 2008 | 04:26 PM
Red Dwarf's Avatar
Red Dwarf
Correct, behind right side lower trim panel.
Old Jun 5, 2011 | 03:15 AM
REWILLIS's Avatar
REWILLIS
1st Gear
Default Fuel pump relay
CAN'T FIND IT. LOOKED BEHIND FUSE BOX. Should I pull up the carpet?
Old Jun 5, 2011 | 03:33 AM
toptechx6's Avatar
toptechx6
You need to drop the carpeted panel above the passengers knees, then look up.
To 95 Lt1 Fuel Pump Relay Location?
