Where is the ESC located??
Old May 1, 2008 | 04:53 PM
goopysteve's Avatar
goopysteve
8th Gear
Default Where is the ESC located??
I want to replace the esc module; where is it & how hard is an R&R job?? Thanks
Old May 1, 2008 | 11:10 PM
JA94vette's Avatar
JA94vette
What year?? I just changed it out on my 94 and it is on the front of the passenger side cyl head above the coil. Very easy to get to. Make sure you put dielectric grease on the back side to promote heat transfer.
Old May 2, 2008 | 08:37 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/El...%20Control.pdf
Old May 6, 2008 | 10:55 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Why do you want to replace it?
Old May 7, 2008 | 12:41 AM
Eddie & the Cruisers's Avatar
I think you are referring to the Ignition Coil Module (ICM) that is mounted on the Coil/ICM bracket. The Knock Sensor Module ('94) is mounted in the PCM cover under a plate. It doesn't have a ESC module.
Old May 7, 2008 | 12:47 AM
Please fill in your profile (top red menu line under USER CP) so we will know your year model, etc. Thanks!
Agent 86 hit it right.
To Where is the ESC located??
