Automated datalogging software?
Old Dec 16, 2001 | 11:41 AM
18carfan's Avatar
18carfan
Cruise-In II Veteran
Default Automated datalogging software?
Ok, since this is up now, I'll go ahead and ask my first question (one of many I'm sure). I ran across a program awhile back that you could plug a datalog file into (I believe it was a file from Datamaster to be specific but I'm not sure) and it would do the number crunching and spit out a VE table. I seem to remember it only being available for and LT1 application. Does anybody know what/where this program is and if so are there versions available for different applictaions - more specifically, the 730/727 SD application? I've cut my calculating time in half using a spreadsheet but that program was very intriguing and now I can't find it. Any help? -Jeff
Old Dec 16, 2001 | 12:08 PM
DOCTOR J's Avatar
DOCTOR J
Default Re: Automated datalogging software? (18carfan)
Jeff
Over on the TunerCat board there was a guy named Georger(?) that wrote a program called VEMaster maybe 9 months ago. If I'm remembering right, that might be the one you are thinking about. It was for LT1's so I never looked at it in detail. HTH
drj
Old Dec 16, 2001 | 02:00 PM
18carfan's Avatar
18carfan
Default Re: Automated datalogging software? (DOCTOR J)
Thanks Doc, I found a few links to VEMaster and that's it. Ok, so it only works with LT1 bins/logs. It looks like it was written in Visual C++ 6. Any programming gurus out there that can adapt it? Maybe that's not even allowed in the written/unwritten rules of the "programming world". Not sure how that stuff works but it would be nice to have a similar program for other applications. -Jeff
Old Dec 16, 2001 | 02:54 PM
Chris@SD's Avatar
Chris@SD
Send a mail to Joe. He is a very nice guy and he might write the code to do what you are asking. Every suggestion we have offered over the last year, he has been more than happy to integrate! :cheers:
If you are using this program, I would use a LARGE log file, and do a few iterations of this in order to get it dead on!
Good Luck,
Old Dec 16, 2001 | 03:07 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
somebody had posted an excel spreadsheet program that you could paste your ve numbers in and blms and it would give you the new table for Tunercat. It was for a 747 ecm though, and rpms stopped at 3400 or so. It could probably be extended to cover more rpms.... I'll see if I can find it. I think I had saved it when I ran across it on gmecm.
Old Dec 18, 2001 | 04:59 PM
Bobalos's Avatar
Bobalos
Is there a Tuner Cat Message board or a Mailing list?
BW
Old Dec 19, 2001 | 01:35 PM
Bobalos's Avatar
Bobalos
Default Re: Automated datalogging software? (Bobalos)
No help here? Dr. J?
BW
Old Dec 19, 2001 | 02:04 PM
HighHopes85's Avatar
HighHopes85
http://www.topica.com/lists/TunerCat -Matt-
[Modified by HighHopes85, 12:05 PM 12/19/2001]
18carfan's Avatar
18carfan
I ran across a mailing list on topica.com that I subscribed to awhile back. Doesn't get a ton of posts but hopefully it will grow. Might check that out. -Jeff
Old Dec 19, 2001 | 02:15 PM
18carfan's Avatar
18carfan
oops! HighHopes and I must have been typing at the same time. He's even got a url - cool! -Jeff
Old Dec 19, 2001 | 04:50 PM
Bobalos's Avatar
Bobalos
Right on, thanks mucho
BW
To Automated datalogging software?
