Whats this part
Old May 4, 2008 | 11:44 AM
Yellow2015's Avatar
Yellow2015
Default Whats this part
After changing my oil today, I was doing a little engine inspection and found a broken vacum line. It's the part below the one with the two wires on it and shaped like a square. The vacum line comes from the front of the car, T's off and one line goes to the left side of the part and the other, which I have unplugged goes to the top connection which you can see. It's mounted just to the rear of the thermostat housing and below the TB.
any ideas?
BTW, it's an 88
Old May 4, 2008 | 12:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That's the vacuum part of the EGR Sol which controls the EGR Valve.
Though you can likely patch the line with rubber hose, I picked up a new line a few years ago for my '88. Over time and temp. cycling those hard plastic lines become brittle and easily crack & break.
ZD1's Avatar
ZD1
TPI? The line coming from the TB is the vacuum source line for the EGR valve. GM added an electronic switch also to this vacuum (the wires in your pic). From the switch it goes the EGR valve underneath the plenum.
This was the first repair I had to make on the vette. A cracked vacuum connection to the TB
Old May 4, 2008 | 12:49 PM
Yellow2015's Avatar
Yellow2015
Thanks guys. The vac line is broken off INSIDE the part and maneuvering room is limited so I guess a pair of needle nose is in order.
Old May 4, 2008 | 04:12 PM
86PACER's Avatar
86PACER
That entire rubber piece is just presses in as well. You can pull it off.
Old May 4, 2008 | 05:21 PM
Yellow2015's Avatar
Yellow2015
Really? Does it pull straight out towards the wheel well or up towards the TB?
Old May 4, 2008 | 08:40 PM
65Z01's Avatar
65Z01
The hard line are integral to that flat rectangular piece; the rectangular piece then plugs into the EGR Sol.
It pulls straight back along the top of the intake base.
Old May 4, 2008 | 08:58 PM
Yellow2015's Avatar
Yellow2015
Thanks 65............it's off.
To Whats this part
