Fuel Pressure Regulator??
Old May 5, 2008 | 10:36 AM
Mlo's Avatar
Mlo
Default Fuel Pressure Regulator??
I have a 95 LT1, and when I trun the key it build about 40lbs of pressure, and when I'm driving its at least that high.
But as soon as I turn it off the fuel pressure drops to zero with in a few seconds, then it doesnt want to start very easy, and sometime it has a rough idle and my volt meter jumps up and down.
Does it make sence for my problem to be a bad Fuel Pressure Regulator?
P.S. The reason my fuel pressure is so high its because I had it tuned for the little cam.
Old May 5, 2008 | 11:14 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Remove the vac line going to the regulator the pressure should go up. My 95 runs at about 42-45lb like this. Next check the injectors for leak down.
