Hidden Build Sheets
Old Dec 16, 2001 | 03:43 PM
KYVette90's Avatar
KYVette90
Default Hidden Build Sheets
About a month ago I found several build sheets stuffed into a hole in my frame by the engine mounts. I found something else last night that is wrapped over the top of my gas tank. Is it probably another build sheet? I havn't tried to get it out yet. Any suggestions on how to remove it? :smash:
Old Dec 16, 2001 | 05:04 PM
Ruby_Roadster's Avatar
Ruby_Roadster
Default Re: Hidden Build Sheets (KYVette90)
Loosen the restaining strap and you should be able to slowly slide it out.
Old Dec 22, 2001 | 11:15 PM
Juliet's Avatar
Juliet
Too cooL! :) I've looked about a dozen times on my car and haven't even found the holes to look in, much less a build sheet! :eek: What's the likelihood of it stil being readable after 108k miles? :D Oh well, at least I have the one from my 1970. :yesnod:
Old Dec 23, 2001 | 12:08 AM
danno85's Avatar
danno85
I'm "rebuilding" my 85 and I took the engine cradle out and I also found a build sheet stuffed up inside (would've been near one of the motor mounts). It was pretty dingy and only half readable. I'll be looking for the one on top of the gas tank when I get to that point.
Dan
Old Dec 23, 2001 | 12:22 AM
KYVette90's Avatar
KYVette90
Default Re: Hidden Build Sheets (Juliet)
My car has 149,000 miles on it and the build sheets were pretty bad. You could still read them though. The one on top of my gas tank looks perfect. I can't get it out though.
Old Dec 23, 2001 | 10:48 AM
c4cruiser's Avatar
c4cruiser
If they seem to be in bad shape, the chances are not too good that they will come off the tank without more tearing.
Why not get them from the Museum?? You can order both the build sheet and the window sticker for your car. If you're not a member, just cruise on over and join up!! :D
Old Dec 23, 2001 | 12:26 PM
KYVette90's Avatar
KYVette90
Default Re: Hidden Build Sheets (c4cruiser)
I could do that, but that would be the easy way. :D
To Hidden Build Sheets
