stock gearing on 96?
Old May 5, 2008 | 07:40 PM
ittybittyfds's Avatar
ittybittyfds
Default stock gearing on 96?
anybody know what the gearing is on the 96 vette/LT1/Auto?
Old May 5, 2008 | 07:43 PM
wayne lowry's Avatar
wayne lowry
Usually 2.59 Check your RPO codes under the center console.
If you have a code GM1 you have the 2.59s
Old May 5, 2008 | 07:51 PM
JimiHendrix's Avatar
JimiHendrix
2:59. If you are worried about aftermarket gears....you could jack up and crawl under the car and rotate your drive shaft 2 and 1/2 turns to see if your rear wheel makes a complete 360. That will confirm it.
To stock gearing on 96?
