Moog lower ball joint......'96
Old May 6, 2008 | 03:48 AM
Weav's Vet's Avatar
Weav's Vet
Default Moog lower ball joint......'96
Can't get any response in General so I thought I'd put this here.
I had to replace my left one. My problem is, The grease boot has to go over a shoulder on the base of the joint instead of inside the lower control arm like the OE did. My mechanic pressed the new joint in and I asked him about the boot. He said it would go over the shoulder when I put it all back together. Well it does some but not all the way. I have tried everything I know of to get it over it completely with no luck. Push one side down the other pops up. Is this the way it's supposed to be? Just kind of sitting there. Thanks, -Mike
Old May 6, 2008 | 08:57 AM
brenb's Avatar
brenb
Are you certain the ball joint is fully pressed into the arm?
I have Moog joints on my 89 and had no problem with the boots.
Old May 6, 2008 | 11:57 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Mine , MOOG , lower went over fine. It does stretch a little. WOrse case call VB&P.
Do you have pics?
Old May 6, 2008 | 05:45 PM
Weav's Vet's Avatar
Weav's Vet
Let me put it this way.....If I could tighten it anymore the cotter key would be worthless. Thanks anyway!
Old May 6, 2008 | 05:47 PM
Weav's Vet's Avatar
Weav's Vet
[quote=steve40th;1565335856]Mine , MOOG , lower went over fine. It does stretch a little. WOrse case call VB&P.
Do you have pics?
Sorry Steve, no pics. I might call them. Still messing with it. Thanks for the input!
Old May 6, 2008 | 08:01 PM
brenb's Avatar
brenb
That's not a good indicator.
The ball joint has a shoulder that should be pressed hard against the lower arm. It sounds like it didn't get pressed in all the way.
Old May 7, 2008 | 01:39 AM
steve40th's Avatar
steve40th
And its only supposed to be torqued to a max, after the intial torque. I agree with not being in all the way.
Old May 7, 2008 | 06:37 AM
Weav's Vet's Avatar
Weav's Vet
The shoulder the grease boot goes on sticks up past the control arm about 5/16 of an inch maybe a hair more. Seems like that would be plenty for the boot to seal on. Anyway, I'm taking it back off and taking it back to my mechanic and let him figure it out. Thanks to you both for your input on this. I appreciate it! -Mike
To Moog lower ball joint......'96
