How to lower the front
Old Dec 16, 2001 | 09:41 PM
danno85's Avatar
danno85
Default How to lower the front
How do the wedges you can buy work to lower the front of the car?
Old Dec 16, 2001 | 09:52 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: How to lower the front (danno85)
The shims are thinner so the chassis sits lower on the front spring; as opposed the the rear end where the chassis is hung from the tips of the rear spring and longer bolts are all tha's required to lower it.
Old Dec 16, 2001 | 09:56 PM
danno85's Avatar
danno85
Default Re: How to lower the front (65Z01)
so the shims go where the spring mounts in the engine cradle/cross member (replacing what is currently there)?
Old Dec 17, 2001 | 11:19 AM
Goody's Avatar
Goody
If you locate a picture of a stock spring you will see to big rubber stoppers on them about 2" high or so. You cut those off and then glue the poly wedges to the frame and then shorten the aluminum spacers adaquately. The wedges should be used so you don't have bare metal rubbing on that glass spring. :eek:
Old Dec 17, 2001 | 10:33 PM
danno85's Avatar
danno85
Default Re: How to lower the front (Goody)
I get the idea now - Thanks!! :cheers:
To How to lower the front
