no overdrive
Old May 7, 2008 | 03:08 PM
byedan's Avatar
byedan
Default no overdrive
I got a call from the mechanic installing the new transmission in my car and he claims that on the lift he can not get the transmssion to go in to converter lock up, i think the problem is i have the coolant temp sensor on the front of the water pump unplugged due to it being bad when i dropped the car off and it would not run. Could this be causing the od problem
Old May 7, 2008 | 08:33 PM
rodj's Avatar
rodj
CTS is major input to run computer functions.Need to replace and confirm correct operation before looking at anything else.
Old May 8, 2008 | 07:56 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My OD will never come on without the CTS.
Old May 8, 2008 | 08:33 AM
rodj's Avatar
rodj
I think without the CTS ,ECM would be in "limp home" mode.
Nearly ever major ECM operation has a temperature input to function.
Old May 8, 2008 | 09:48 AM
byedan's Avatar
byedan
thanks guys this is what i though but was not sure how much this would effect drove the car on the road and it actly runs. now my a/c controll is showing ---
To no overdrive
