Vette Tech Tri-Y Status?
Old Aug 10, 2008 | 09:53 AM
  #241
TJM's Avatar
TJM
Originally Posted by GREGGPENN
Interesting... I decide for the head/cam swap (vs adding a blower) by thinking the opposite. I felt pressurizing the 20-yr-old stock motor could lead to more problems than rebuilding the top-end for N/A gains. And, it would be resealed to prevent old-age leaks.
I do think these (1 3/4") headers are a good choice for a blown street car though!
No doubt in my simple mind.
The blower takes care of one end. the headers, the other.
Now to find a cheap blower?
TJM
Old Aug 12, 2008 | 01:01 AM
  #242
Yguy's Avatar
Yguy
A quick question......
On the return fuel line, about 6-8 inches from the fuel rail connection, is some sort of diaphragm looking device. Anyone know what this this is or does. (NO diaphragm/birth control jokes please)
I tried to get a pic, but the camera is outta gas. It's now recharging.
Old Aug 12, 2008 | 07:24 AM
  #243
anesthes's Avatar
anesthes
To keep the fuel rails from making noise. Some years had a huge canister on the frame, others had the stupid little breath-mint-can looking thing. My sisters fbody has one too.
Without it, the fuel rail line pulsates and makes tons of noise.
-- Joe
Old Aug 12, 2008 | 07:26 AM
  #244
TJM's Avatar
TJM
I'll check the book and look at my '89 tonight.
Why is it broken or something?
TJM
Never Mind... sounds like you got the right answer
Old Aug 20, 2008 | 10:13 PM
  #245
STEVEN13's Avatar
STEVEN13
Hi,
I received my header back. It is far from perfect-but it is installed. The tube still had to be hammered to fit.
The other issue: He never checked to see if a bolt would fit, after it was reworked. Had to grind the weld and hammer the heck out of the #2 tube for the bolt to go in. A real pain in the A$$!!
Also the #2 and #4 tube (where they join in the Y) is missing a weld in between. I asked Brian to please fix this and he said that he would. However, he did not...I hope it does not leak! Anyways I am done with Brian.
Sorry for the rant!
Steven
P.S. I will post my dyno results and track results (If I get to the track this season).
Old Aug 21, 2008 | 12:25 AM
  #246
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by STEVEN13
Hi,
Sorry for the rant!
Steven
I wouldn't call that a rant. You're just saying what happened. After seeing how crowded (my smaller) 1 5/8" pipes were between the mounting holes, I wondered if the larger size would make bolt installation difficult for that size.
On Vader's site, he suggests barely starting each bolt first -- to allow wiggle room for insertion of bolts. Then tighten everything down. Is that the technique you used? IOW, was there simply no way to get around beating it up? Did you have any problem with the other bolts?
Corvette Bob said his (#2 shortened) set barely cleared the control arm. And, he's still concerned it might hit some day. I'm guessing your suspension adjustments made the problem even worse. Or do you think standard camber would have presented the same issue? (Sounds like Bob would have voted for more adjustment than Brian accomplished).
Have you gotten a chance to try them out yet?
Old Aug 21, 2008 | 08:06 AM
  #247
anesthes's Avatar
anesthes
Gregg,
What are you using for headers now? I ended up with the 2051s. They install in 30 minutes and clear everything. I wish the 2061s didn't leak but oh well.
I think you guys should bail on these tri-y's until someone can make 'em right. Hammering tubes and grinding doesn't sound very appealing to me.
-- Joe
Old Aug 21, 2008 | 12:33 PM
  #248
GREGGPENN's Avatar
GREGGPENN
Originally Posted by anesthes
Gregg,
-- Joe
Do you mean 2151's?
I'm still in line for a redo on these Tri-Ys. Not sure I could cancel w/o having to resell. Originally he said I could return mine, but I gave him the chance and asked for specific changes. He know's I want drop-in fit.
FYI: He's not the one who makes the headers. I now know he goes to another shop. (Maybe Tom had the right idea.)
Old Aug 21, 2008 | 12:50 PM
  #249
anesthes's Avatar
anesthes
Do you mean 2151's?
Err yeah 2151s.
Too bad you guys are having soo much trouble. for the money (that I saw them selling for on ebay) they should just work.
-- Joe
Old Aug 21, 2008 | 04:32 PM
  #250
TJM's Avatar
TJM
Err yeah 2151s.
-- Joe
This thread has a life of it’s own!!!!!!!
Aside from beating #2 tube they fit great.
If it is a Looonngg tube header you want theses puppies are surely IT..
The 3” Y pipe is an extra cost, but the fit and finish are over all, good. Great Ground clearance, too.
Total out the door with the Ceramic coated “Y” was $875.00 [ not counting what I screwed up trying to fab up a Y].
The question is: “Does the performance match the cost and work?” This ain’t give away cheap??
I have to adjust fuel pressure this evening, [ new 22# FIC injectors] and if no rain she should be able to recalibrate herself tonight for a “Seat Of Pants” dyno check.
I have to say; .... I do like everything but the beating part.
But, speaking frankly, if your selling C4 parts you should have a “Mule” to test for just this thing. Brian should have had that pipe properly flattened, to clear the A arm.
If he had, you all would be singing his praises [ maybe?].
TJM
Old Aug 21, 2008 | 07:02 PM
  #251
TJM's Avatar
TJM
Yes
Well, 43-1/2Lbs of fuel pressure set and 30 minutes of Mr. Good Citizen driving and the computer was pretty much calibrated.
Nice tone. Great idle, like new thank you Jon.
Now, with everything nice and warm, No odd sounds or lose parts? …..No.
Time for irresponsible …“Seat ‘O Pants” …. tests.
From a dead stop, at idle, the full throttle launch made a cloud of smoke, and I fish tailed 100’. Second made the tail twitch a tad [ this is an automatic ].
Well, she never did that before [ I have had this car since 1996]? Injectors or headers??
Stock injectors 22Lbs. nothing fancy.
50mph to 120mph in a 5 - 6 second count. No OD, 3rd gear. Very unscientific, but it was pulling hard at 5,000 rpm. [3.07 rear end].
There it is, totally subjective. Figure what you will.
TJM
Old Aug 21, 2008 | 10:45 PM
  #252
STEVEN13's Avatar
STEVEN13
Hi Greg,
Believe me when I say I know how to install a set of headers. There was NO WAY to get that bolt in (shorter bolt, stud with nut, wiggle room, whatever.) I don't mind so much the clearance issue with the control arm as he did not have a C4 to mock-up (why-I don't know). What gets me is that who ever did this change on that tube did not check before getting them coated. Also the weld missing between the 2 and 4 tube should of been addressed.
Regarding the camber, I do think that a stock alignment setting would be ok with these headers. However, Brian did tell me he roadrace C4s. The alignment setting on a roadraced C4 is similar or more (negative camber) than mine. So I do not believe he roadraced a C4 with these same dimensioned headers.
I have not tried them out yet-still have to fab the exhaust. I have been busy with work and have not had the time to play in the garage.
I will take it to the dyno when completed. I am not expecting any big increase-just hoping the torque is a little higher and sooner within the range. Also hope that its louder.
Steven
Old Sep 1, 2008 | 07:45 PM
  #253
84raptor's Avatar
84raptor
1st Gear
Hi,
I've had the Vette Tech tri-y's installed (1 and 5/8") on my '84, going with 3" mandrel bent stainless into a Magnaflow X-pipe, and 2 and 1/2" stainless coming out into a pair of Magnaflow mufflers. Sound is great and performance is ALOT better, to say the least.
The shop that installed the headers said they went in quite easily. The only issues were having to "indent" the front primary on the passenger's side in order to thread the header bolt properly, and also to trim back the 3" expander on the driver's side. I also placed some radiant heat shield (self adhesive type) around the fuel lines and the brake lines where they came very close to the headers. No other issues with clearance.
Old Sep 2, 2008 | 06:50 PM
  #254
TJM's Avatar
TJM
Originally Posted by 84raptor
Hi,
Congratulations. That makes two use, [maybe three ]that have accomplished this.
I am waiting for someone really serious to run a Dyno on a set.
My Derriere Dyno is not ll that scientific!! Steven?? Bob??
TJM
Old Sep 2, 2008 | 07:52 PM
  #255
STEVEN13's Avatar
STEVEN13
TJM
Hi,
As soon as I get the exhaust done, I will make an appointment to get it dyno'd.
All is complete (engine side) even got the computer tuned via PCMforless. I hope to have it running in a few weeks.
Steven
Old Sep 3, 2008 | 01:33 AM
  #256
Jeff M's Avatar
Jeff M
Steve,
Can you post a few pics of the passenger side?
jeff
Old Sep 3, 2008 | 02:26 AM
  #257
Yguy's Avatar
Yguy
TJM
Sorry Tom,
My Buttometer can only render very subjective, rather than Objective,
results. In the meantime, I have located a prospective tuner. As for my install, jsup has been trying to send me his fuel lines. His description is of very high quality and durability, while he's offering them to me at 1/2 price. He seems like a pretty good guy, so I'm willing to wait to see what he has to offer.
To Vette Tech Tri-Y Status?
Old Sep 3, 2008 | 06:30 AM
  #258
TJM's Avatar
TJM
Sorry Tom,
Can't wait to hear!!!
TJM
Old Sep 3, 2008 | 11:06 AM
  #259
STEVEN13's Avatar
STEVEN13
Originally Posted by Jeff M
Steve,
jeff
Jeff,
I will email some photos. Did you get the other photos I sent?
Steven
Old Sep 11, 2008 | 07:46 PM
  #260
Jeff M's Avatar
Jeff M
Steve,
Sorry for the late reply, I'm actually out of the country for a while. I did receive the other photos, looking forward to seeing the passenger side. Also do you think you'd be able to take a few pics from underneath once you have everything done? I'd like to see how you connect your exhaust.
Thanks again...
jeff
