Check engine light & cooling fan ?
Old May 11, 2008 | 07:32 AM
MR NICE's Avatar
MR NICE
Default Check engine light & cooling fan ?
Hi All,My check engine light is on,I checked for codes it only flashes code 12,Also the Cooling fan is on at start when cold &hot (runs constant)I hate to just throw parts at it,from the search I did it may be a fan relay,but the check engine with no code has me a little stumped,Has anyone had the same problem?85 model
Old May 11, 2008 | 02:26 PM
CFI-EFI's Avatar
CFI-EFI
The fan may be on as a part of the limp home mode. Have you waited for the fourth "12" to flash? Each code flashes 3 times before it moves on to the next code. One possible cause of both the light and the constant fan is a failed ECT sensor. You can do an ohm check to test it. Does your car have the auxiliary fan?
RACE ON!!!
Old May 11, 2008 | 03:07 PM
MR NICE's Avatar
MR NICE
RACE ON!!!
Yes it has a small aux. fan.the main fan is running constant,I don't know if the aux fan is running also.I'll check for codes again but 99% sure no codes.Also I disconnected batt to clear codes,Started car check engine light was on at start up.
Old May 11, 2008 | 10:00 PM
CFI-EFI's Avatar
CFI-EFI
I wasn't so concerned with whether the aux fan was running or not. I asked if you had an aux fan, because the main fan is wired differently depending on whether you have an aux fan or not, on an '85 only.
I ***-U-ME you mean that the check engine light came back on after the engine was restarted. It is supposed to come on when the ignition is turned to "on" before the engine is started. The recurring code is to be expected after the code is cleared, if the fault that caused to code hasn't been fixed.
RACE ON!!!
Old May 13, 2008 | 03:47 PM
MR NICE's Avatar
MR NICE
All is well got a code 15 tracked it down to a broken wire 410ckt.FSM works great!
Old May 13, 2008 | 07:27 PM
CFI-EFI's Avatar
CFI-EFI
Imagine that! Circuit 410 is the feed from the ECM to the ECT sensor.
An amazing tool, that FSM. I'm glad you've found the problem and fixed it.
RACE ON!!!
To Check engine light & cooling fan ?
