car shut down
Old May 11, 2008 | 09:51 AM
blck90vette's Avatar
blck90vette
Default car shut down
1990 vert,,,had 3 injectors put in,last thursday,,,picked up car friday,,running great,,,,went to movies sat. night witht the wife,,,after movie,,unlocked wife`s door (the gentleman that i am,,lol),,unlocked doors,,walked around,,i think wife relocked doors,,anyway,,alarm went off,,i shut it off with my key,,,,,,started car up, (battery voltage was normal),, in about 5 seconds,,car shut down,,,could not restart,,,sounded as if it wanted to start, but wouldn`t..the more i tried to crank it,,i could see battery voltage start to drop...friend towed back to mechanic,,,tried to start it this morning (sunday) again no luck,,could hear fuel pump..no codes have been pulled yet. .my question is, do you think this has something to do with the injectors? or can the VATS actually shut down the car... battery ??,,,just trying to get an opinion from all of you,,thanks,,,will keep you informed,,,
Old May 11, 2008 | 09:59 AM
Demonic85's Avatar
Demonic85
Yes the Vats can disable the ignition. Usually sticking the door key in the door and unlocking it will disable the system unless somethings wrong.
Old May 11, 2008 | 10:52 AM
blck90vette
i did shut off the alarm, by unlocking driver side door,,,do you think the alarm is still enabled ? if so, how does one clear it ? i didn`t even know the 90 had this feature. still pondering if those new injectors might be the culprit,,,,,
Old May 11, 2008 | 01:07 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
3 injectors going out at the same time, not likely. I think you try and reset everything by disconnecting, wait a few minutes and reconnect the battery. Also, I have heard to disable the security system, you have to unlock the passenger door.
Goodluck!!
Old May 11, 2008 | 01:37 PM
blck90vette
***UPDATE*** went back to mechanic`s (it`s sunday,he`s not there) car started,, i let it idle,,after 3-4 minutes,,car shut down again..and wouldn`t start up again,,,,left frustrated,,,could vats shut this down? or is it the new injectors that were installed a couple of days ago....i know it could be a # of things just trying to get your thoughts
Old May 11, 2008 | 01:50 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
It is not the FI's, you have a vats or similar problem.
Old May 11, 2008 | 01:59 PM
blck90vette
just confused,,why she started up,,then conked out again after 3minutes of idle,,i would think if it were a VATS issue,,she wouldn`t start at all,,thanks for your input
Old May 13, 2008 | 06:24 PM
blck90vette
my mechanic had the car for 2 days now,,monday: no codes,,injectors read fine,,fuel pressure fine,,his thought was maybe a new ecm,,,,,,tuesday(today),,,he installed new ecm,,,and still car wants to crank over,,,but won`t i feel he`s at his wits end,,,,hoping for some suggestions or thoughts,,,,,,,could the rebuilt ecm possibly be a bad one?,, thanks
Old May 13, 2008 | 06:31 PM
seenalot's Avatar
seenalot
FICINJECTORS answered your question in your other post.
http://forums.corvetteforum.com/show....php?t=2023883
When relpacing Mutlitec injectors, do all eight at once.
Old May 13, 2008 | 06:51 PM
blck90vette
even though they are all reading ok,,are you saying there is still a short somewhere?
Old Jun 4, 2008 | 04:00 PM
blck90vette
update....bought 8 bosch yellowtops from Jon at FuelInjectorConnection,,,,wadda you know, car started right up,,thanks for all you did 4 me jon
To car shut down
