How do you get codes for troubleshooting?
Verne :seeya
:cheers:
Give it a try. If you have no trouble codes stored of course it will flash up 3 12s followed by 3 more 12s.
This all assumes you have an OBD-I setup. What year is your Vette??
[Modified by 65Z01, 9:40 PM 12/17/2001]
BTW, if you have any trouble codes you will need to reset the ECM. This is done by removing power to the ECM for about 1 minute. Either disconnect a battery lead (which will reset your radio and clock) or better open the connector in the orange wire comming from the battery (this lead supplies power only to the ECM).
[Modified by 65Z01, 12:32 AM 12/18/2001]
94 and 95 jump 4 to 12(4th from left on top and the one under) and with the key on engine not running watch speedo you can do the same with a 96 but you will not get ECM codes that you need an OBDII scanner.
David Fulcher
http://members.tripod.com/theviperpi.../ecmcodes.html
http://members.tripod.com/theviperpit/vette/ecm.html
this is very helpful. I have no experience pulling codes like this. However I have a 1996 LT4 which is I believe OBDII. Can you give me a little quick tutorial similar to this one for OBDII? How do I go about pulling codes for this system? Is the the plug-in similar? Is the "blink" method the same?
Any help is appreciated.
You might want to try this web site that offers a "freeware" package for down loading the OBD II codes to a computer:
http://www.blacky.co.nz/efilive/
I haven't tried it yet but the interface is very simple and the "Read Me" file gives a list of what all the codes mean.
[Modified by Wildride, 10:24 AM 12/20/2001]
David Fulcher
