hood rattles
Old May 15, 2008 | 10:16 PM
rithsleeper's Avatar
rithsleeper
Default hood rattles
my driver's side of my hood is rattling. any ideas of how to tighten it down?
Old May 15, 2008 | 11:46 PM
85vet's Avatar
85vet
Cruise-In V Veteran
All you need to do is adjust the stud/post that holds the hood down. If you look at it, the bottom has a large nut that you will have to loosen and then screw the stud/post in. After adjusting the post, tighten the large nut.
Old May 16, 2008 | 12:54 PM
rithsleeper
is it possible that the nut is welded on? I took the entire post out w/ the three bolts surrounding the spring assembly and there is a bolt welded on the bottom but I put the huge nut in a vice (it was too big for even my biggest adjustable wrench) and hit it a few times but not too hard. I dont want to damage anything. But it didnt even budge.
To hood rattles
