A question to the AFR Users
Old May 15, 2008 | 11:50 AM
BlackHarleyMan's Avatar
BlackHarleyMan
Default A question to the AFR Users
What head bolts and part numbers did you use? I'm looking at ARP, and just want to make sure I'm getting the right set.
http://store.summitracing.com/partde...1&autoview=sku
Old May 15, 2008 | 03:21 PM
silver86's Avatar
silver86
I used:
http://store.summitracing.com/egnsea...+115&y=13&x=43
Old May 15, 2008 | 03:26 PM
arozenstraten's Avatar
arozenstraten
Navigator
I used ARP 234-4301. They're studs so they're a lot more expensive. I though it would be good insurance since I'm running boost.
Old May 15, 2008 | 03:52 PM
Orr89rocz's Avatar
Orr89rocz
i am using the same as in the link...but the motor isnt up and running yet bolts look great with my red/black theme tho
Old May 15, 2008 | 04:08 PM
BlackHarleyMan
arozenstraten- I'm not sure that I need studs, but if I were boosted, I could see the logic in that approach! My compression is going to be just under 11:1 normally aspirated.
Orr89rocz- Which link? Better yet, which ARP part number are you using?
Old May 15, 2008 | 06:17 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
If your using lt1 block i would use the studs
The Lt1 have open holes and leak water.I also use the mr gasket A-2 sealent on the bolts to seal the water jacket threads on the stud or bolt
Old May 15, 2008 | 10:31 PM
Orr89rocz's Avatar
Orr89rocz
haha sorry there were two links posted..i mean the first link, the 3601's i think it is for 63 bucks
Old May 15, 2008 | 11:42 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I have studs on a couple of cars and not on others. I much prefer regular bolts for two reasons. Some of the head bolts (or studs) tap into water passages. A few of the studs will leak coolant right up through the threads of the studs. After you do your re-torque, a few more will leak. And don't forget, some of the studs with possible leaks are under the valve covers.
Head bolts are much less problematic.
Secondly, if you ever have to take the heads off with the engine still in the car, it's 2x more difficult with studs.
My experience.
Old May 15, 2008 | 11:51 PM
cv67's Avatar
cv67
St. Jude Donor '05
First time I used studs I freaked, seeped for almost a week and eventually corroded themselves shut like the machinist said they would.
Thing is it wasnt my motor so I REALLY got an earful about how I f'd it up. Hey, he wanted studs, he got it.
Still running to this day though.
Total waste on a NA motor.
Old May 16, 2008 | 12:54 PM
rklessdriver's Avatar
rklessdriver
ARP 134-3601 (6pt) or 134-3701 (12pt)
Either will work. No need to spend $155.00 on the "Pro Series" (234 -) bolts.
Will
Old May 16, 2008 | 03:37 PM
Orr89rocz's Avatar
Orr89rocz
studs are great on aftermarket blocks that have the head bolt holes seperated from the water jackets...no worries from leaks there
To A question to the AFR Users
