Head light won't go down
Old May 16, 2008 | 11:48 PM
85 paulie's Avatar
85 paulie
Cruising
Default Head light won't go down
The left side head light motor on my 85, after 23 years of fathful service, died, so I installed a brand new one, it worked for about 2 weeks and now it will not go down, have to do it manually, I took the motor apart, and could not find any thing wrong, put it back in and it still won't go down, any help would be great, thanks
Old May 17, 2008 | 12:17 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Does the motor run, is it getting power, will the headlight go up???
Old May 17, 2008 | 08:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old May 17, 2008 | 11:13 AM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Check all the obvious. Any shorts in the wires, are the connectors tight, etc...
By the way, 'wouldn't go down' is certainly a problem in my neck of the woods too.
Old May 17, 2008 | 07:29 PM
85 paulie's Avatar
85 paulie
Cruising
Yeah, the motor runs, head light goes up, just won't reverse to go down, will recheck everything, this going down thing seems to be an epidemic everywhere
Old May 17, 2008 | 07:42 PM
65Z01's Avatar
65Z01
Does the motor stop running when the light goes up or continue to run?
You could unplug the headlight door controls and jumper the LH motor to the RH side to see if it operates; if so the problem is in the wiring or the controller.
Old May 17, 2008 | 08:41 PM
85 paulie's Avatar
85 paulie
Cruising
once the head light is up the motor stops running, I'll try jumping it to the right side, thanks, that's a great idea
Old May 18, 2008 | 12:28 AM
cgb86c4's Avatar
cgb86c4
My 86 did the same thing and in ended up being a relay problem. They are located under a cover in front of the front driver side wheel.
Old May 18, 2008 | 12:52 AM
85 paulie's Avatar
85 paulie
Cruising
Thanks, where did you buy the relay?
Old May 18, 2008 | 01:45 AM
CoolVette86
Be careful, the Right Hand headlight door motor gets the "Down" voltage from the isolation relay. Check Agent86's diagram. It's actually easier to follow along using the factory service manual. If you get one, it's easily the best investment for your car. Good luck.
Go here for fair priced GM parts with fast shipping:
http://www.tld-corvette.com/products.asp?dept=686
Old May 18, 2008 | 09:34 PM
cgb86c4's Avatar
cgb86c4
I ordered it from zips. If memory serves me right it was the center relay of the 3 that is under the cover.
To Head light won't go down
