Oil temp high
Old May 17, 2008 | 09:00 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by Aardwolf
Does your year car not give an exact temp? If not I have an idea, measure the sensor itself. There was a chart if I remember in the service manual that converted volts to a temp, that could help tell you where it actually is for a temp.
When I get the data cable this week, I'm going to do that. Readings from the ECM will be more accurate.
Old May 18, 2008 | 09:56 AM
jsup's Avatar
jsup
Originally Posted by 65Z01
I think that's because you are tunning so lean.
Does it still run hot with the new O2 sensor?
BTW, my oil temp usually runs about 10-15deg F above coolant temp in warm weather.
Is the tune really lean? Can we determine that with a bad O2 sensor? I really don't know.
