'85 With No Oil Temp Reading
Here's my problem:
I'm getting oil pressure readings on my instrument display, but I'm not getting any oil temperature reading...it just displays 0 degrees. Can someone tell me where the oil temperature sensor is located and the color wire that is attached to the sensor.
The engine has been changed out with a pre '81 non-Corvette engine...that's what I was told...because the dip stick is on the wrong side. The engine harness was not changed out. There is some type of sensor on the left-middle side of the block with a single terminal green wire attached to it...is that it?
I ran the engine until the coolant temp was 180 degrees, from what I've read in an earlier Corvette Forum thread, the oil temp should be about 10-20 degrees hotter than the coolant temp.
Any help would be appreciated
Here's my problem:
The oil takes a long time to heat up compared to the coolant.
May not be running long enough or able to get to temp in the garage.
